Exhaust leak from turbo
I have an 08 job 1 truck that leaks exhaust smoke under the cover that is over the turbo. The problem only occurrs during the regen process, typically towards the end of the cycle. When at a stop light it comes out the hood, the fender side grill and enters the cabin when the heat or ac is on. Two dealers have tried to solve the problem but can never make it occur.
Any insight would be greatly appreciated?
they have to do a manual regen and then they will see it.
see the tsb
Exhaust leak in engine compartment:
Some trucks may have an exhaust odor inside or exhaust smoke may be visible around the front. This could be caused by a leak at the turbo outlet from a misaligned downpipe. Verification requires disconnecting the turbo oil supply tubes (replace the banjo sealing washers, W302474) and removing the turbo heat shield to inspect. If the leak is at the turbo outlet, the downpipe will need to be repositioned to seal correctly, with a new downpipe to turbo gasket (7C3Z-6L612-B) and v-band clamp (7C3Z-5A231-AC), and new nuts for the downpipe to catalytic converter flange (W711407-S900). If properly installed, the downpipe will be 11/16" +/- 1/8" from the frame rail. TSB 07-7-7
see the tsb
SSSimon
01-04-2011 05:07 AM
