2008 F250 6.4L powerstroke problem**Help
I have a 2008 with 6.4L powerstroke. 144,000 miles. I have driven since it was new. Never any motor problems, always kept up regular maint. I did buy a bullydog E3 programmer. NOT DPF delete, just a tow program. I had the program installed since about 75K. Back in december there was a notice sent from Ford about a re-flash to PCM. I took it in for the Re-Flash and returned the program to stock. Ever since the Re-flash, my bullydog is inoperable. Bullydog says the new calibration wiped out their ability to use that programmer. No problem but ever since then, i have been losing power (over 2300 rpm) and it is random. Just acts like it is almost in limp mode. I can pull over and cut off and restart and the condition goes away for a period then comes back the same. I am getting a P0088 code which says fuel system pressure too high, but after hooking up on a ford diagnostic tool, the pressures dont show too high? Has anyone experienced the same or have any suggestions
