OBD-1/EEC-IV connector issue...
Old 12-11-2011, 08:27 PM
ManicMike's Avatar
ManicMike
ManicMike is offline
Well something is up with my truck's connector. I can't get my code reader to work with it. I've tried multiple different time's, new battery's nothing seems to work. I know the scanner works, I've used it on my mustang plenty of times and just for the hell of it I went to my friend's '89 mustang with it and it instantly worked.
I CAN get codes out of the truck using the paper clip method. I'd just would like to use my code reader since it's easier.
Anyone have idea's?
Here's the code reader I have:
http://www.amazon.com/Equus-3145-For.../dp/B000EW0KHW
-Mike
Old 12-11-2011, 08:29 PM
White 97 xlt's Avatar
White 97 xlt
White 97 xlt is offline
Try some contact cleaner in the plugs on the truck. While you have the plug wet, plug in the reader a few times. They crud up and give grief sometimes..
Old 12-11-2011, 09:33 PM
ManicMike's Avatar
ManicMike
Hmm, I'll give that shot. Thanks!
Old 12-12-2011, 04:19 PM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,165 Likes on 920 Posts
X2..I also have used a small screwdriver to scrape off the crud....
Old 12-12-2011, 05:40 PM
Scndsin's Avatar
Scndsin
Scndsin is offline
I don't remember if it was a I or II obd Ford truck I couldn't get my equus to work on, but it turned out to be a fuse in the truck.
Old 12-12-2011, 06:44 PM
ManicMike's Avatar
ManicMike
It only work's on OBD-1.
I did a combination of things. I sprayed it with electrical cleaner, used a screwdriver to dig more crud out then used the unit itself.
End result is I got it to work. Thanks guys!
bashby
11-21-2014 07:25 PM
3spd
05-01-2011 07:28 PM
2005f-150
03-18-2011 07:49 PM
DCRB
Aerostar
09-16-2007 12:00 AM
Broncobigtire
1978 - 1996 Big Bronco
08-31-2004 03:57 PM
Quick Reply: OBD-1/EEC-IV connector issue...
