Gear shift linkage
Old 10-30-2011, 10:09 PM
Vinford's Avatar
Vinford
Vinford is offline
Gear shift linkage
Has anyone changed there gearshift indicator cable?
How hard to change or adjust is it?
I dont seem to have 1st gear and a couple of times Ive slipped out of park and it rolled away.
Once across Walmart parking lot narrowly missing 3 other trucks.
Old 10-30-2011, 10:43 PM
twags6's Avatar
twags6
twags6 is offline
The indicator cable has nothing to do with what gear your actually in. The shifter linkage could be out of adjustment though, not putting the trans fully in park. I'm not sure on the exact adjustment procedure though.
EDIT: Here's how to adjust the shift linkage. https://www.ford-trucks.com/forums/8...djustment.html There's also a few links at the bottom on how to adjust the pointer and fix a sloppy shifter.
Old 10-31-2011, 07:36 PM
Vinford's Avatar
Vinford
Vinford is offline
If the indicator/cable isnt moving far enough, would that not let it go into 1st when you pull it right down?
Old 10-31-2011, 08:36 PM
BigAlsPSD's Avatar
BigAlsPSD
BigAlsPSD is offline
It is kinda tricky to get lined up correctly if you are not familiar with it, but easiest to place truck in a known gear and "align" everything to there, the first "adjustment" I would recommend you check is the torx screw under the dash here's a pic of them.
Name:  Torx screws.jpg
Old 11-01-2011, 12:20 PM
twags6's Avatar
twags6
twags6 is offline
It shouldn't. The cable for it is the size of a paper clip and the setup is all plastic. It would give if you pulled too hard.
marvinlong
35
08-16-2020 10:58 AM
LCA078
07-11-2016 12:33 PM
ronquillaw
03-21-2015 02:05 PM
Dustin1690
09-24-2007 05:32 PM
fnx4wheeler
08-17-2006 12:43 PM
Quick Reply: Gear shift linkage
