Parking gear slips sometimes
Recently and only every once in a while when I place her in Park, the truck will roll forward/backward and I hear the loud pop/click from the parking gear/lock not fully engaging. I pull the gear selector to Drive or such and then forcefully push in Park to make sure it's fully engaged.
Is there a linkage I need to adjust or does this signal a failing part? I just had a Ford reman 4R100 put in less than 20K ago but not sure if that has something to do with it. Thoughts?
Can't speak about the internals of the transmission but wonder if your shift lever is loose and tranny not going all the way into park. There are 2 bolts under the dash that can back out and cause a loose connection between the lever and shift linkage. Check those. here's a video on how to
Received 3,102 Likes
on
on
hightower45
1997-2006 Expedition & Navigator
06-08-2004 07:34 AM
