Need Pic of Toyota PS Box and 30 inch column
Old 09-27-2011, 10:23 PM
tjdad62's Avatar
tjdad62
tjdad62 is offline
Hey guys,
I have a 50 F-3 and I have fab'd the mounting bracket for the box. I got a 30 inch "ididit" column and the proper u-joint to connect it with. With my 4.5 inch column drop it looks as if the angle on my steering box mount may be too steep. To make it work, I may have to cut out a small semi-circle from the top end opening where the original column went through.
If I could get a pic of how yours is installed I can get a better idea about whether or not I have the wrong angle for the mount bracket. I got it as close to 45 degrees as I could. If I have to redo it, so be it. Just wanted to be sure before I sliced into the firewall to make a hole that isn't needed.
Old 09-28-2011, 12:20 AM
yamagrant's Avatar
yamagrant
yamagrant is offline
I just installed the same kit in my 56 and have a 32'' column with a 4.5'' drop and I find the column at leat 2'' too long. ( due to wheel expansion of course ) When I'm done with the seats I will measure and replace accordingly.
Old 09-28-2011, 12:59 PM
jaye's Avatar
jaye
jaye is offline
Mine may not do you any good since its on a 55;angle isn't that great either...:-)
Old 09-28-2011, 01:08 PM
yamagrant's Avatar
yamagrant
Your u-joint angle is good, just modify or make a new floor plate.
Old 09-29-2011, 03:32 PM
tjdad62's Avatar
tjdad62
tjdad62 is offline
I have a 30" column and loosely installed it to get an idea of how it will look and discovered that I need to go with a 32" column and a 2.5" column drop rather than a 4.5 that everyone else seems to be using. I have 1987 Astro Van seats sitting up on 2 inch risers, so maybe that has something to do with it. After I put the column in, the knee clearance was crappy and the shifter would have hit the dash when going into park.
Old 09-29-2011, 09:23 PM
dongc1's Avatar
dongc1
dongc1 is offline
Here are some pictures out of my gallery. I have a 30" Flaming river column. The column drop is very short.
https://www.ford-trucks.com/user_gal...186261.520.390
https://www.ford-trucks.com/user_gal...163750.520.390
https://www.ford-trucks.com/user_gal...163756.520.390
jerryst
01-02-2017 08:00 AM
1949f1
04-15-2016 03:12 PM
Branded
17
01-05-2014 10:16 AM
theGman
12-17-2004 09:39 AM
wosborn
04-11-2004 12:05 PM
Quick Reply: Need Pic of Toyota PS Box and 30 inch column
