what order
Old Dec 31, 2016 | 06:42 PM
jerryst's Avatar
jerryst
what order
Well I got my steering column and drop bracket. How do I go about setting up the drop bracket? I was thinking of mocking up column and then put on column drop and see where to mount it. Or is there a easier way? Thanks for all the help. And before I forget this is for a 1955 f100 with power steering box added.
Happy New Year.
Thanks
Jerry
Old Jan 1, 2017 | 02:11 PM
filthy6's Avatar
filthy6
Happy New Year.
Thanks
Jerry
Hopefully someone smarter than me will be along shortly.On my '56 I used the IDIDIT column, CPP power steering box and firewall brake kit. I think the column is thirty inches long and the column drop is 4 1/2". I'm using a universal joint for the column box connection. I just connected it all up and had my helper support it. I sat in the seat I was going to use, and determined which drop was going to work best. For our trucks it seems that 4 1/2'" drop is a good place to start. I think I used the 30" IDIDIT column. I would have to check that to be sure.
Old Jan 1, 2017 | 10:52 PM
jerryst's Avatar
jerryst
I guess i worded it the wrong way. I have everything done except the drop and installing the column. I am trying to find out how and where to mount the drop for the column. I was going to put on the u joint and loosely mount the drop in line with the hole in the floor to the power steering box. What do you all think? Sorry for all the confusion.
Thanks
Jerry
Old Jan 2, 2017 | 08:00 AM
jniolon's Avatar
jniolon
old and in the way
Jerry... usually the drop is centered on the gauge panel.... mine was a little different...
maybe this will give you some ideas..
john
http://jniolon.classicpickup.com/col...columnin_a.htm
1949f1
Apr 15, 2016 03:12 PM
SuperDuty93
Sep 15, 2013 05:07 PM
turnrjr
Sep 5, 2011 01:26 PM
snoopypup
Jun 14, 2006 12:48 PM
mrwillie66
May 7, 2005 01:16 PM
