valve cover gasket?
valve cover gasket?
in*lbs, in*lbs guys. Marty, do yourself a huge favor and spend the extra$$ and buy the 100% rubber gasket, don't settle for the cork/ rubber composite. The cork will eventually wick out oil. Use a hand held nut driver and only tighten enough to have it snug. I assume you got your rig up and running, welcome back. The change out isn't tough. Take the air cleaner off, disonnect the throttle linkage at the carb - I think there's a bracket to remove too, maybe the fuel line also. A lot depends on the web of hoses and wires that snake over the cover. The only trouble spot can be next to the t-stat. With the hose on, the clearance is tight, but doable. If you swap covers, keep the old one. It should have all the info you need on the stickerS to set the timing, idle, and vacuum circuit calibration number.
valve cover gasket?
ok , thanx.. yea i got it running a little better. not much i still want to redo the timing and replace some vacuum lines..so while im changing the gasket im going to change my t-stat to..that gasket is all soaked with oil so i figure its a cheap part and im sure ill have to change it sooner or later...so ill do it now....thanx for replies..
mike L
13
10-25-2015 01:32 AM
Dave Massingham
03-08-2014 03:00 AM
