78 f150 starting problems
Old 07-28-2011, 10:23 PM
JB78f150's Avatar
JB78f150
JB78f150 is offline
I'm having trouble getting my 1978 f150 351m started. I replaced the distributor because it was cracked. When it was all timed and running awesome i took it for a test drive. When i got back to the house it just shut off. No sputter or anything just off. Since then i replaced the fuel pump and tried to start it. It turns over but no start. When i turn the key back it sounds like it ignites but it doesn't start. The truck is pretty much original except the distributor and fuel pump. Never had a problem til now ran it everyday for a couple months. Any help would be greatly appreciated.
Old 07-28-2011, 10:49 PM
mikeo0o0o0's Avatar
mikeo0o0o0
mikeo0o0o0 is offline
Check to see if you have spark. My guess is the igniton control module.
Old 07-28-2011, 11:18 PM
JB78f150's Avatar
JB78f150
JB78f150 is offline
I have spark from the coil will the ignition control module stop the spark?
Old 07-28-2011, 11:36 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Is the distributor hold down clamp tight? Check the timing to make sure it hasn't changed.
If you have compression and fuel, the only thing left is properly timed spark.
Old 07-29-2011, 06:02 PM
JB78f150's Avatar
JB78f150
JB78f150 is offline
Checked the ignition control module today. It is good just not sure where the problem is. It doesn't sound like its getting spark. Does the ignition switch have anything to do with it. The starter comes on and there is plenty of fuel but its not firing. The wires and spark plug are brand new last month. Anything else it can be?
Old 07-30-2011, 06:00 PM
JB78f150's Avatar
JB78f150
JB78f150 is offline
It was a broken wire in the bottom of the distributor.
Old 08-09-2011, 03:35 PM
JB78f150's Avatar
JB78f150
JB78f150 is offline
So I got the knew distributor today. I put it in it starts but its really rough. I set the timing but still is missing. Not sure of the symptoms of a 180 out. Would it even start? Also another problem i'm wondering about is what are the symptoms of timing chain jump?
Old 08-10-2011, 05:21 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Double check and make sure you have the firing order right, that all the wires are connected to the correct plug.
Distributor rotates COUNTER CLOCKWISE.
Firing order: 1 3 7 2 6 5 4 8
Cylinders are numbered front to back 1-4 passenger side 5-8 drivers side
Old 08-10-2011, 01:33 PM
JB78f150's Avatar
JB78f150
JB78f150 is offline
Thanks for the suggestion 4 and 5 were out of order. Runs like a dream again.
Old 08-10-2011, 06:02 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Glad you got it fixed.
Gryphon1962m
22
04-24-2022 11:27 AM
Desireg
09-25-2015 05:22 PM
lonerangermotors
12-13-2012 03:50 PM
jmoats91
22
05-30-2008 04:10 PM
tkrocks
03-23-2005 07:52 AM
Quick Reply: 78 f150 starting problems
