intermintent spark
Old Mar 22, 2005 | 05:59 AM
tkrocks's Avatar
tkrocks
intermintent spark
i have a 1988 f250 fuel injected 460 i jumpered a screwdriver from coil wire to
where it plugs onto the disturditor cap when i first turn the key i get a spark
briefly than nothing anyone have a idea sometimes it will start and run for a while but if i shut it off i have to wait an hour or so than it will start.
Old Mar 22, 2005 | 06:21 PM
fast_st's Avatar
fast_st
Well, it could be a number of things, this system can't be 'jumped' easily, check the harness between the TFI module on the distributor and the coil for any breaks in the wiring, check the connectors for corrosion as well. Hot start could be a TFI module, or it could be the pickup coil inside the distributor, check it for resistance, should have a couple ohms if its in good shape.
-Jason
Old Mar 22, 2005 | 06:28 PM
tkrocks's Avatar
tkrocks
I replaced the tfi module still didnt fix it i will keep everyone posted
Old Mar 22, 2005 | 09:17 PM
fast_st's Avatar
fast_st
Trying to recall the operation, on power up the tfi cycles, latching the fuel pump on for 4 seconds or something, then the fuel pump shuts off until it sees a spark signal, so, key on, listen for the fuel pump to cycle, crank the engine and see if you hear the fuel pump cycle again, it might point out a faulty pickup coil.
Old Mar 23, 2005 | 06:25 AM
tkrocks's Avatar
tkrocks
I do hear the pump turn on then truck run for a bit than dies no spark held bleader valve on fuel rail open while a friend cranked it over lots of fuel
its getting frustateing thanks for all the help i will keep all posted. ido have power to the coil when i turn on key how do you cahange pick up coil thanks
Old Mar 23, 2005 | 07:52 AM
fast_st's Avatar
fast_st
Hmm, do you have a multimeter available, even a $20 auto ranging one from radio shack could save some headaches. your coil looks like a little brick right? you'll need to check resistance values between the two low voltage terminals in the plug and between each spade terminal and the high voltage contact. If you need the numbers, I have the book around someplace. The pickup coil is down in the bottom of the distributor, under the rotor, little small dice sized thing that has the wires running to it from the distributor plug.
-Jason
