Cab bushings
Old 05-22-2011, 11:37 AM
bamaf150's Avatar
bamaf150
bamaf150 is offline
Cab bushings
Finally have gotten around to replacing the rubber bushings for the cab and have a question for anyone who has done it. I used the search feature and brings up a gazillion posts but I havent found one specifically dealing with my question. Can I just jack the cab up with everything mounted and replace the bushings? Are there any things I should loosen before I raise the cab such as fenders, linkages etc? I'm thinking I wont have to jack it much to do this but just wondering. Going to have to remove the in cab tank to do the rear mounts looks like.
Old 05-22-2011, 11:48 AM
impalaslayer's Avatar
impalaslayer
impalaslayer is offline
i dont see why you couldnt just lift it alittle bit to slide the new one in.
Old 05-22-2011, 11:56 AM
bamaf150's Avatar
bamaf150
bamaf150 is offline
Thats what I'm thinking (hoping).
Old 05-22-2011, 12:04 PM
impalaslayer
have fun with the old ones though, if they are anything like mine you will make up new words and try not to throw up from the smell of burning bushings.
Old 05-22-2011, 12:27 PM
mudder460's Avatar
mudder460
mudder460 is offline
I couldn't get my original bushing to come apart, you are supposed to hammer them apart...or atleast try to that is. I ended up jacking the cab up a little bit, cutting them apart with a sawzaw and then making new bushing supports.
Old 05-22-2011, 12:32 PM
2002fx4122's Avatar
2002fx4122
2002fx4122 is offline
It took a punch and a 20lb sledge to get all my mounts off my 77's frame. Where did you get your bushings? and are you reusing the hardware
Old 05-22-2011, 12:35 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
make sure you unhook the steering column at the rag joint or you will ruin it. I found out the hard way.
Old 05-22-2011, 01:33 PM
impalaslayer
i did the same, and it smells terrible!
Old 05-22-2011, 02:02 PM
bamaf150's Avatar
bamaf150
bamaf150 is offline
Ahh, thats the stuff I'm wondering about, thanks. I intend on reusing the hardware and I have the poly kit from Bronco Graveyard.
Old 05-22-2011, 05:08 PM
starwriter's Avatar
starwriter
starwriter is offline
When I replaced my bushings, I replaced both the bushings and the mounts. It was the easiest way I saw of doing it since my mounts were pretty much shot anyways. I got a set of these and drilled the mounts out from the bottom.
High Speed Steel Step Drills & Other Step Drill Bits - Harbor Freight Tools
It made it extremely easy to remove the old mounts. Here were my steps
1) Drill out old mount from bottom
2) Jack up fram using a 2 x 4 about an inch higher than the new mount.
3) Place new mount.
4) Bolt it down.
I didn't have to remove or loosen anything. As mentioned I watched my rag joint but since I only jacked up an inch or two no damage was done. I got new mounts from Jeff's bronco graveyard and poly bushings.
Old 05-22-2011, 06:48 PM
bamaf150's Avatar
bamaf150
bamaf150 is offline
3) Place new mount.
4) Bolt it down.
Did you take the bolts out first, I'm guessing yes? When you say the bushing and the mount, what do you mean? Not the mount thats welded to the frame itself? I have the same poly kit as you, I'm hoping all Im going to have to do is remove bolts, jack it up and slide in new bushings. I already took my rag joint loose as a precaution, took 5 minutes to do. I'm hoping the rest of the hardware under there is good, this truck came from no-rust-New Mexico and every bolt or nut I have ever messed with on it comes out like it was put on yesterday. I pulled the seat out and removed all the bolts and lines to the in-cab gas tank, draining it now, probably work on the bushings during the week, thanks for all the tips guys.
Old 05-22-2011, 07:26 PM
starwriter's Avatar
starwriter
Correct, I removed the bolts holding the "body mount sleeves" together. The body mount sleeves are the part with the mushrooming heads that compress and hold the bushings in place. Before I choose to drill them out I tried everything I could to get them out, including a punch and 20lb sledge, heat, PB blaster, etc. Mine would not budge and for the ones on the core support and front of the cab getting a sledge in was impossible. I got a kit that had all new sleeves (6) 12 pcs total. I got new grade 8 bolts as well. I figured if I was going to do it I didn't want to do it again. I removed the bolt holding the sleeves together and drilled them out from the bottom. For most of them the bottom mushroom head broke free and I slid off the bottom bushing and slit the rest out from the top. I then replaced bushings and sleeves and bolted it back together. This was 2 years ago now and I have had no problems and a lot less noise.
Old 05-26-2011, 06:34 PM
bamaf150's Avatar
bamaf150
bamaf150 is offline
Ok, so these are tougher than I hoped so I ordered new bolts and sleeve/washers. Question, when I jack up the cab, which when I say jack it up, I mean just enough to slide old stuff out, new in, do I need to unbolt the front clip anywhere such as the inner fender support? I dont want to warp anything.
Old 05-26-2011, 10:30 PM
starwriter's Avatar
starwriter
I don't remember loosening anything other than the mount I was working on. I would just take my time and listen as I jacked up the body.
Old 05-26-2011, 10:41 PM
moose4x4's Avatar
moose4x4
moose4x4 is offline
If your body parts are off the frame. take a longer bolt and screw into the bushing like you were mounting the body. Then take the big hammer and knock it downwards. The punch just seems to make it worse, worked real good on my frame. This will only work if the body is off the frame.
lafermedavid
03-17-2023 04:08 PM
Speedjester
07-23-2015 03:06 PM
crazed87bronco
10-28-2014 12:51 PM
BossFan
06-20-2014 08:49 AM
cghstrojan08
15
07-14-2010 08:25 PM
Quick Reply: Cab bushings
