Truck dies like no fuel
Old Jun 5, 2026 | 06:01 AM
96_Bear's Avatar
96_Bear
Trailering
Truck was running great, pulled up to stop and started idling rough. Drove about 3 miles and started running out of power, pressing on pedal just makes it sputter and dies. Towed home, ran forscan and scanner these are codes and screen shot from vid while cranking to see ficm,icp,ipr numbers. Tank is full, pump is Motorcraft 14 months old and does fill upper filter housing still. Any help to point me in right direction is greatly appreciated.
Forescan screenshot during crank
Scanner DTC's
Scanner DTC's
Old Jun 5, 2026 | 06:54 AM
BLADE35's Avatar
BLADE35
Looks like charging system/battery problems may have killed FICM
more info required
VOLTS
FICM MP
FICM LP
FICM VP
charge and load test battery
Check cables
test alternator
it’s also cranking to slow need 150+ rpm
Old Jun 5, 2026 | 07:08 AM
96_Bear's Avatar
96_Bear
Trailering
more info required
VOLTS
FICM MP
FICM LP
FICM VP
Check cables
test alternator
Yes was cranking in the screenshot, this was 11.9V from batteries after 3 or 4 cranks for about 10 seconds. The ficm voltage changes between 48 and 48.5 v while cranking .
Old Jun 5, 2026 | 07:29 AM
runthatjunk's Avatar
runthatjunk
https://www.ford-trucks.com/forums/1...g-process.html
Read this and get data asked for
Old Jun 5, 2026 | 08:03 AM
bismic's Avatar
bismic
As posted above - there are THREE important FICM voltages, not just one (VPower and LPower in addition to MPower). Especially since you have FICM codes and one code is for bad LOGIC power (P1378: FICM detects logic power low, less than 7 volts).
P0611: FICM memory fault. Loss of FICM Power or internal FICM failure: FICM memory fault will set if a RAM or ROM fault exists. Loss of FICM Power. Other internal FICM failure. That said, you will get this code with a FICM that has been modified for higher voltage.
Also as stated above, ALSO your cranking rpms are insufficient for a reliable start (150+ is what you want to see).
IMO you will be needing another FICM (known good) to try (as stated over on the ORG). Or send the one you have in for testing and upgrading (CircuitBoardMedics.com or FICMRepair.com).
Old Jun 5, 2026 | 03:34 PM
96_Bear's Avatar
96_Bear
Trailering
more info required
VOLTS
FICM MP
FICM LP
FICM VP
Check cables
test alternator
Think I got ask for information . This is a cranking video and screen shot.
Screenshot of cranking
File Type: mp4
Old Jun 5, 2026 | 03:38 PM
96_Bear's Avatar
96_Bear
Trailering
I do have spare FICM that was good when removed this truck, I can try it. Both FICM are 48v not 52v. I can hear fuel pump run and watch the upper bowl fill up, should it almost spray out or just over fill and pour out? Getting ready to put metal cap with pressure port in a little bit to test pressure.
Old Jun 5, 2026 | 04:20 PM
bismic's Avatar
bismic
It will quickly fill and pour over.
Old Jun 5, 2026 | 04:22 PM
bismic's Avatar
bismic
We also need Cam/Crank Sync and the ICP sensor volts (ICPV) - when cranking.
Old Today | 09:15 AM
96_Bear's Avatar
96_Bear
Trailering
more info required
VOLTS
FICM MP
FICM LP
FICM VP
Check cables
test alternator
Lowest I've seen voltage on ficm lp was 9.5. All others never below 10v. I have power or lower side of the Ficm to try and replace yet those numbers show good from what I can tell. Is this a logic side issue? New completr Ficm will be here on the June 27th .
Vid screenshot while cranking
Old Today | 09:49 AM
bismic's Avatar
bismic
9.5v Logic Power is bad.
Old Today | 10:11 AM
96_Bear's Avatar
96_Bear
Trailering
EDIT: FOUND ANSWER this is power side. Is this the logic or power side that needs replaced?
FICM repair
FICM repair
Old Today | 10:21 AM
bismic's Avatar
bismic
Sorry I do not recall the components that directly create the logic power. I have a guide somewhere on that that I can look for.
That said, IMO getting that number means it needs to be sent in for repair.
VGVForrest
Jun 16, 2025 08:41 PM
Rooster45
46
Feb 21, 2025 07:25 AM
arca
21
Dec 13, 2024 07:41 AM
Bigsilver95
Aug 24, 2021 01:19 AM
edub32
15
Mar 10, 2009 10:53 PM
