reverse gear problem
Old May 12, 2026 | 11:54 AM
philippe de marseille's Avatar
My 1992 F-150 5.8 with automatic transmission "slips" when I shift into reverse.
There's no problem going forward, but when shifting into reverse, I have to accelerate for it to start moving backward.
Does anyone have any ideas?
The oil level is fine.
Thanks
Old May 12, 2026 | 11:56 AM
90project5.0's Avatar
90project5.0
Which auto trans do you have?
Old May 12, 2026 | 02:36 PM
aod box
Old May 12, 2026 | 08:02 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Ford did not put the AOD behind the 351W in a truck so was it swapped in by you or someone else? What is the transmission code on the driver’s side B pillar?
Old Yesterday | 06:54 AM
The best thing would be for me to provide you with a photo of the plate on the box.
Old Yesterday | 01:45 PM
My4Fordtrucks
or you could look at the pan and match it up to a transmission ID chart easily found on the internet. This is one I got by searching for Ford transmission ID chart…
Old Yesterday | 04:10 PM
it's a E4OD
Old Yesterday | 04:24 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
There are feedbolts between the valve body and the case. If they loosen, they can cause this. If they are tight, about the only other way this could happen is a damaged reverse clutch.
Old Today | 01:39 AM
Thank you for your reply; I'll take this opportunity to replace the filter.
How many liters of oil should I order, and what type?
Old Today | 08:25 AM
Mark Kovalsky
Get 8. It may not use all of those, but sometimes they do,
Old Today | 08:34 AM
1Butcher's Avatar
1Butcher
If I were to change the fluid in my transmission, I would drain the converter. I believe the factory converters had a drain plug [my 95 did]. I am not a fan of mixing old and new fluid and do what I can to prevent that. I swear, mine took about 16 quarts or more.
If you elect to dive deep in the transmission, what are you going to do when the plate gasket tears? I would have a new one. I would also know exactly where all the ***** should be when they fall out.
Knightrocker
2004 - 2008 F150
Jan 25, 2010 10:30 PM
asok
Oct 14, 2009 02:53 PM
cjbronco
1978 - 1996 Big Bronco
Jan 24, 2005 06:42 PM
SgtJoe
Aerostar
May 24, 2004 03:27 PM
