Delete Done - Command Start Not Working
Hi everyone, as the title reads I recently had a delete done, and disaster kit installed. Got it back, everything was good but the command start isn't working. No CEL, there was a sensor unplugged when I got it back, but I plugged it back in and still no go.
Anyone have this happen?
The following 3 users liked this post by senix:
2016. The truck starts with the key in ignition. In Canada we have a command start where you push a button in the house and the truck starts.
After the delete mine just honks (normal) but doesn't start.
Also, check to make sure it is actually enabled, it may have become disabled due to the PCM reflash
Remote start is enabled on your vehicle's instrument cluster. To check your settings:
- Ensure your vehicle is on, running, parked, and in a well-ventilated safe area.
- Locate the directional arrows on your steering wheel.
- Go to Settings > Vehicle > Remote Start > System.
Note: Some panels are different and may be listed as Settings > Advance Settings > Vehicle > Remote Start > System. - Set Remote Start to On, which is represented by a check mark.
After market remote start doesn't tie into the PCM the same way as OEM does. IOW it dont care what condition the vehicle is in, it will start it. The OEM has protection mode, which is what I believe the OP situation is.
