Truck won’t start code P062A
Old Jul 13, 2020 | 03:03 PM
PGS67's Avatar
PGS67
Truck started fine this morning drove 40 plus miles parked the truck. Got back in it 2 hours later tried to start truck nothing. When you turn the key to Accessory I can’t hear the fuel pump making any noise. Also when you try to start it the starter stays engaged.
Old Jul 13, 2020 | 03:22 PM
senix's Avatar
senix
P062A Fuel Pump "A" Control Circuit Range/Performance
Start with fuses.
Old Jul 13, 2020 | 09:00 PM
PGS67's Avatar
PGS67
I checked the fuses and relays and they seem
ok.
Old Jul 14, 2020 | 05:02 AM
senix's Avatar
senix
then I would start with wring and connections.
Old Oct 24, 2020 | 02:35 AM
Scott Morse's Avatar
Scott Morse
Did you figure out your issue, mine just did the same thing.
Old Oct 25, 2020 | 07:44 AM
PGS67's Avatar
PGS67
I had to change out the fuel pump. It started right up after I stall
Old May 25, 2024 | 10:52 PM
walkerandrews's Avatar
walkerandrews
1st Gear
ok.
what fuses did you check? Also did you have to replace the fuel pump or the sending unit?
Old Nov 10, 2025 | 09:17 PM
MichaelD2140's Avatar
MichaelD2140
1st Gear
Samenissue 2015
What fuel pump? The tank pump, the one on the frame u der the drivers seat, or the cp4 pump?
fordf350man
22
Nov 23, 2016 03:46 PM
Erin A Lynch
Nov 4, 2014 11:24 AM
Trailblazed
Oct 4, 2009 01:26 PM
Colin94Supercab4.0
1983 - 2012 Ranger & B-Series
Jan 21, 2004 01:39 PM
