Delete Done - Command Start Not Working
Old May 23, 2024 | 06:34 PM
Stormbreed's Avatar
Stormbreed
3rd Gear
Hi everyone, as the title reads I recently had a delete done, and disaster kit installed. Got it back, everything was good but the command start isn't working. No CEL, there was a sensor unplugged when I got it back, but I plugged it back in and still no go.
Anyone have this happen?
Old May 23, 2024 | 09:52 PM
senix's Avatar
senix
go back to where you had it done and get it returned to the way it was. Not a good tune or company if it already is a problem.
Old May 23, 2024 | 11:30 PM
Stormbreed's Avatar
Stormbreed
3rd Gear
Not gonna do that, he's already offered to get it working I was just trying to see if anyone else had similar issues.
Old May 24, 2024 | 12:38 PM
Sport45's Avatar
Sport45
What is command start? Do you mean the truck won’t start? Also, what year is your rig?
The sensor that was unplugged may be meant to be unplugged with the tune.
Old May 24, 2024 | 02:07 PM
Stormbreed's Avatar
Stormbreed
3rd Gear
2016. The truck starts with the key in ignition. In Canada we have a command start where you push a button in the house and the truck starts.
After the delete mine just honks (normal) but doesn't start.
Old May 24, 2024 | 04:51 PM
acdii's Avatar
acdii
We normally just call that remote start. Any car with factory remote will not start if, (a) the battery is low (b) there is a system fault or (c) there is a set code in the PCM. Chances are there is a code set that does not engage the dash CEL. Quite common with a delete.
Old May 24, 2024 | 06:40 PM
honda250xtitan's Avatar
honda250xtitan
thats odd. OEM remote start? my 12volt solutions remote start worked fine before and after delete.
Old May 25, 2024 | 11:09 AM
acdii's Avatar
acdii
After market remote start doesn't tie into the PCM the same way as OEM does. IOW it dont care what condition the vehicle is in, it will start it. The OEM has protection mode, which is what I believe the OP situation is.
Also, check to make sure it is actually enabled, it may have become disabled due to the PCM reflash
Remote start is enabled on your vehicle's instrument cluster. To check your settings:
  1. Ensure your vehicle is on, running, parked, and in a well-ventilated safe area.
  2. Locate the directional arrows on your steering wheel.
  3. Go to Settings > Vehicle > Remote Start > System.
    Note: Some panels are different and may be listed as Settings > Advance Settings > Vehicle > Remote Start > System.
  4. Set Remote Start to On, which is represented by a check mark.
Old May 25, 2024 | 12:23 PM
honda250xtitan
ah makes sense. mine has a little box you tie into a couple of the OEM harnesses. ignition and somewhere else. 10 min install. but anyways.
Old May 25, 2024 | 05:49 PM
displacement4me's Avatar
displacement4me
Aside from checking/clearing codes, check the hood pin. It needs to show hood closed for startup - a belly or tool could have damaged it etc.
tlt64
Nov 12, 2020 05:13 PM
Ryanfits74
2009 - 2014 F150
Mar 27, 2017 07:08 PM
Ford from above
Jun 1, 2004 07:43 PM
