1972 F250 Under Dash Heater Diagram
Now that I have solved my shift **** problem, my next task is to figure out what I am missing with the heater. Does anyone have a picture that shows how the heater is connected in the cabin, under the dash. My heater blows hot air all the time, and I am suspecting I am missing some bits and pieces. I have attached some images of what I'm looking at, so if someone could help me identify what I'm missing, I would greatly appreciate it.
That's what I figured, at least as far as the ducts were concerned. I think it looks like I need two flexible tubes to connect to the defrost diffuser. And maybe some other pieces that go onto that plastic piece that says "OFF" "DEF" "ON" And yes, I have heat all the time, but nothing come out of the defroster vents.
Here are a couple of threads with some pictures that show the heater & the parts diagram:
Heater Core replacement - Ford Truck Enthusiasts Forums (ford-trucks.com)
Heater Fan Not Working - Ford Truck Enthusiasts Forums (ford-trucks.com)
'68 F250 daily driver - Page 5 - Ford Truck Enthusiasts Forums (ford-trucks.com) starts at #63
I have attached images of the hose connections to the heater, and images of the heater control cable in positions of "Low" and "Warm" Quation #1: Are the hoses connected correctly? Question #2: Since it doesn't make any difference which position the engine bay cable control is in, I still get hot air: does that mean what ever the cable is controlling is faulty?
By the way, there is no adjustment I can see, as both ends of the cable are fixed.
By the way, what is that red doo-hickey on the other hose?
Slide switch in "Low" position; connector in engine bay full forward
Connector full forward; slide switch in "Low" position
Slide switch in "Warm" position; connector in engine bay full back toward firewall
Connector full back toward firewall; slide switch in "Warm" position
Last edited by zippospeedcat; 05-21-2024 at 10:16 PM. Reason: Add comment regarding fixed cable length; red doo-hickey
Here are a couple of threads talking about hose routing & the temp control valve. My valve was rusted inside and would not move. The red item on your one hose is for flushing out the cooling system, they would hook up a flushing machine to it.
Heater Hose Water Valve - Ford Truck Enthusiasts Forums (ford-trucks.com)
Heater blows hot air even when off - Ford Truck Enthusiasts Forums (ford-trucks.com)
Well, imagine my surprise! I ordered a new heater valve, but in the meantime was able to pick up a used one at a local Ford Truck yard. I examined the used valve I got and the valve worked smoothly, so I removed the one in my truck, and looked at it. The inside looked exactly the same as the one I got from the Ford yard and worked the same, but I thought "Oh well, let's try it." And whaddya know - NO hot air when the valve is off. What I don't understand is why the old one in my truck didn't seem to be closing even though the cable was bottomed out at the stop and looked and operated like the one from the Ford yard. Somehow, hot water was getting around the closing mechanism, even though ti wasn't obvious how.
Thanks for all the help on this little episode. Now it's on to replacing the defroster ducts
on
purplewg
21
10-15-2019 04:57 PM
Heinz5774
10-29-2018 02:58 PM
