Factory Topper T-Handle Replacement
Hey All, I've got a factory topper that came without a key so I picked up a NOS T-handle with key. I removed the two bolts that hold the handle to the shell, I figured it would slide out of the latch once these were removed but no luck. My latching mechanism isn't in the best shape, and I cant tell if its just seized in there or if I'm missing something. Figured I would ask if anyone has any experience here before I break something. Here are some pics.
FWIW the handle as been stuck in that position since I got the topper. I'm not sure if its stuck, locked, broken etc.
Sooooo! Where did you find that NOS T-handle? I've been looking for one. Also, what Broktruk said. You gotta pop those clips up and the rods will slide out. The latch will come out easily then. I bet if up clamp it in a vise and soak it in WD40 and start moving it around, it'll be operating like new again.
@SlikWillie They pop up on ebay from time to time. I watched a few go by before finally pulling the plug, the prices are pretty steep but its nice having a functioning topper. Let me know if you need the factory part number for searches.
Finally wrapped this up tonight. I hate an unfinished thread so I figured I would post up here in case anyone runs into the same issue.
As far as I can tell, I should have been able to pop the handle out with the latch mechanism in place, but that wasn't happening. A little PB blaster and a new latch got it all together. Unfortunately the old handle broke on the way out. Thanks for the help!
Here ya go! Should be D3TZ 9943400-B and you can find everything you need here: https://www.fordification.net/partnos/bedcover.htm
The latch mechanism should be D3TZ 99404A50-A Looks like ones for same now here: https://www.ebay.com/itm/125079091500
abe
03-12-2023 09:48 PM
F2spiffy
20
08-03-2021 05:23 AM
Justin03PSD
07-04-2011 02:51 PM
