Buying Used
What year are you looking at? Makes a big difference in what quirks are there and need to be looked out for. Only real constant is emissions equipment is a concern on all model years.
2011-heads were possibly bad, causing catastrophic engine failure, glow plugs were too long catastrophic engine failure, earliest model of CP4.2 higher rates of failure depending who you talk to
2011 to 2014- weak SST turbo, supposedly they upgraded the bearings in them for 2013 model year, it is difficult to find hard data on this
2015 to 2016 -upgraded CP4.2 injection pump, bigger/more reliable turbo, weaker transmission, not really important unless tuning it
2017 to 2019- upgraded parts and aluminum body, haven't heard of a lot of major issues other than emissions equipment, and that's becoming fewer and farther between as they continue to improve the systems
this is all subjective and somewhat opinion based, it all depends completely how the vehicle was taken care of by it's previous owner, sometimes it's hard to tell after a dealer sends it through the detailing bay or shop.
2011's had a bad valve design. It was a two piece design and if it came apart then the motor was trashed. The check was to pull the glow plugs. There was also a revised to the plugs from this and a bit of a resign of the heads.
Radiators are always a weak spot. Plastic.
There was a time when coolant leaks in the valley of the motor were an issue, resolved mostly by 2013. It was a resign of the connections for coolant to the turbo.
An inspection of all exhaust components is important.
The 6.7's are having issues with leaking upper oil pans from the factory. Even the 17+ trucks still have this issue. The bots are not applying enough silicone in the corners, which is causing oil seeping. Most will be repaired under warranty. Unless you crawl under the truck and look you wouldn't notice the leak (it's not enough to drip on the ground). Only reason I mention this is because it's a rather labor intensive fix to get at the upper oil pan.....The transmission has to be removed to access the upper bolts on the upper oil pan. We haven't had enough feedback from users if this issue returns later down the road or not.
This is after 10k miles
