F350 6.0 Low voltage at start up -11.5volts
I have 6.0. It cranks over ok but normally needs two cycles of the glow plugs before it will fire up. All brand new injectors and the FICM is at 49 volts. The battery voltage is at 11.5 at start up and the alternator is clearly working as once running, in a minute or three, the voltage is up to 12.5 and once on the road 13.5 to 14.
As a side note, I run HID lights. one side is working the other is not until I get on the road and the voltage comes up. I am wondering if the batteries are done and the low voltage is causing my two issues.
Any advice would be great.
I had a similar voltage issue on my 04 6.0 but i have stock headlights. Chased my tail all thru the electrical system . Ultimately the issue was the battery harness cable that connects bothg positive battery terminals. It runs along the top of the radiator.
You need to grab a muti meter and start probing around. Mine had a short and was hot to the touch due to extra resistance.
To fix it i bought Ford OEM battery wiring harness from for around $110. It runs from the starter up to the passenger battery and connects to the driver battery.
You can check for degraded connections/cables by checking for excessive voltage drop across each "jumper" cable during the glow plug cycle and cranking action. Check neg to neg and pos to pos separately and look for very low voltages across what is supposed to be a direct connection.
[QUOTE=projectSHO89;18421398]That was not a "short". A true short would have caused one or more of the following: Smoke, fire, or blown circuit protection devices, if any. Yours had "excessive resistance" (probably due to internal corrosion) which is the exact opposite of a short.
Good call SHO ...Thats what i meant to say.
Havent had my coffee yet and brain stuck..
You need to have the batteries load tested. Keep in mind the glow plugs will run for up to 2 minutes depending on temperature after the glow plug light on the dash turns off. Will the voltage come up if you just let in sit with the engine running after the glow plugs turn off. Sounds like you have multiple issues as you should not have to run the glow plugs multiple times before the engine will start. Again I think having the batteries load tested is step one.
MuddyWaters
08-02-2010 11:34 AM
