Wondering if my trailer brake controller is working.
Hi everyone. I have a 2012 F-350 Diesel. I tow a few different trailers. The one I'm questioning is my travel trailer. It's not too heavy considering what can be towed by this truck. It's 8000 lbs unloaded, maybe 9 or 9500 lbs loaded. When I have my other trailers hooked up with load it can be 6-10,000lbs I usually have my controller set to about 5 or 7. Now with my travel trailer fully loaded I find I have to adjust up to 9 or even 10 to be efficient. That doesn't make sense to me. What if I had a heavier load? The controller seems to work. I have tried it on it's own. It does slow everything down as I depress it alone. I realize the trailer brakes are not as heavy duty as the trucks brakes but I expected them to resist more under use. Would this be considered normal? What's your guys experiences out there? If your hauling with a fifth wheel or goose neck does it work the same. Obviously loads can go up to about 30,000lbs! What do you do then? Same system? I'm full of questions lol. Thanks.
What do you call " efficient " ? The Ford TBC works differently than most controllers.... Does the manual brake (Controller) slow the RV down at 5 or 7? Can you feel it pull the rear of the truck down? Have you ever felt when stopping that the trailer is pushing you? I think it's prob working fine so long as the tralier's brakes have been checked and are good. Have you pulled the wheels to see if there has been grease embedded on the rotors?
If your controller is working with other trailers, you do not have controller issue, you have a trailer issue. First make sure your trailer brakes are adjusted. If that doesn't do it, work back through the connections to your trailer to see where you are losing amperage.
With your trailer hitched, but your seven pin unplugged, pull your break-away pin and try to pull your trailer. That will tell you how well your brakes are working at their maximum amperage.
I've pulled a 24' box trailer that is 10,000 GVW and a 22' flatbed that is 20,000, both with a 2023 F350 . The box trailer brakes worked well but the flatbed gave me the "trailer disconnected" message every time the brakes were activated. The flatbed has a lot more miles on it, but all lights and signals worked fine. I checked my ground, my 7-pin connector, and everything in between but couldn't find any issue. The flatbed's trailer brakes worked great behind my 2019 F250. Took trailer and truck to a shop and everything tested good. Took the wheels off the trailer and turns out the brake magnets were worn. I guess the new truck is more sensitive than the 2019. Changed magnets and all is good - no more "trailer disconnected" and the trailer brakes work well.
tony montana 42
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
09-13-2017 10:11 AM
MYTRUCKNOWRATTLES
6.7L Power Stroke Diesel
53
11-27-2013 08:50 AM
brkncly
6.4L Power Stroke Diesel
10-25-2012 01:18 PM
