Sponsored by: Real Truck
Adjusting gain on brake controller
Old May 16, 2016 | 05:09 AM
phydeauxman's Avatar
phydeauxman
Retired Livin the Dream
I have a 14 250 that I use to pull my 5th wheel with. I just installed disc brakes on my trailer and now need to set the gain on the brake controller. I have changed the brake controller to be E/H...what is the appropriate procedure to follow to set the right amount of gain on the controller?
Old May 16, 2016 | 05:15 AM
redford's Avatar
redford
FTE Leadership Emeritus
Note: This should only be performed in a traffic free environment at
speeds of approximately 20 – 25 mph (30 – 40 km/h).
1. Make sure the trailer brakes are in good working condition,
functioning normally, and properly adjusted. See your trailer dealer if
necessary.
2. Hook-up the trailer and make the electrical connections according to
the trailer manufacturer’s instructions.
3. When a trailer with electric brakes is plugged in, the trailer connection
indicator will illuminate green on the TBC and the GAIN setting display
will illuminate.
4. Use the GAIN adjustment (+/-) buttons to increase or decrease the
GAIN setting to the desired starting point. (A GAIN setting of 6.0 is a
good starting point for heavier loads.)
5. In a traffic-free environment, tow the trailer on a dry, level surface at
a speed of 20 – 25 mph (30 – 40 km/h) and squeeze the manual control
lever completely.
6. If the trailer wheels lock-up (indicated by squealing tires), reduce the
GAIN setting; if the trailer wheels turn freely, increase the GAIN setting.
Repeat Steps 5 and 6 until the GAIN setting is at a point just below
trailer wheel lock-up. If towing a heavier trailer, trailer wheel lockup may
not be attainable even with the maximum GAIN setting of 10.
Old May 16, 2016 | 07:41 AM
madjak's Avatar
madjak
Thank you Redford,
Good info for adjusting the trailer brake controller.
jimmystoys
All Things Towing
Jul 31, 2023 02:20 PM
tony montana 42
All Things Towing
Sep 13, 2017 10:11 AM
Gary Lewis
2015 - 2020 F150
17
May 22, 2016 07:29 PM
JS-SD
Jun 17, 2013 02:55 PM
vatreefarmer
Nov 5, 2007 02:58 PM
