84 2WD Front Brakes .. how involved?
I was going to do the pads and rotors for my 84 F150, but the rotors were out of stock locally. And, they apparently are "integrated hub" .. which seems scary.
What is involved with replacing them? Any special tools like presses needed? Should i replace the bearings at the same time? Anything else?
What parts are needed, if any, besides pads and the rotors/hubs?
I had to buy a disk brake hardware kit as my old parts were worn/beat-up and rusty, but the kit is only about $10-$12 iirc. Not a bad idea to have if you're dealing with any rust issues.
Took me about 4 hours to do both sides, replacing nearly everything (bearings rotors, pads, calipers, hoses, hardware)
Might want to do wheel bearings while you’re there and now would be the time to do ball joints if there ever was.
Integrated hub means the brake rotor and hub are one piece.
You can buy rotors with the bearing races pre-installed. Doesn't add much to the cost. I would really spring for new hardware, about 0.95 a set from rock auto. The slide pins are tension-fit, so they can shrink over time.
James Wagoner
26
07-25-2019 01:26 PM
