brake replacement
Old Oct 23, 2004 | 08:04 PM
stecz's Avatar
stecz
brake replacement
The front rotors on my 2000 excursion (2wd) are warped bad...
Do the rotors come off of the front separate from the bearings, etc, or do I have to totally disassemble the front, replace the bearings, etc when I replace the rotors?
I'll do pads at the same time even though they are not worn out.
Thanks
John
Old Oct 23, 2004 | 08:51 PM
rozett's Avatar
rozett
Nope, you do not need to touch the wheel bearings to remove the rotors.
Old Oct 24, 2004 | 03:16 PM
stecz's Avatar
stecz
cool, then I'll fix that right away.... that's a simple project in that case... I may not even replace the pads since they have a lot of wear left...
Old Oct 26, 2004 | 10:15 AM
stecz's Avatar
stecz
oops.. that's wrong.. on the 2wd, the rotor is not separate from the hub. I'll need to put new bearings/races in.
On the rear and on 4wds, the rotor is separate, just take off the wheel and caliper and the rotor will come off.
Old Oct 26, 2004 | 06:34 PM
hothilton's Avatar
hothilton
to continue with brake replacement question, in addition to slotted rotors and performance brake pads, are stainless braided hoses a necessary option? Thanks
Old Oct 27, 2004 | 03:52 PM
stecz's Avatar
stecz
Stainless hoses are not a requirements. There are some drawbacks to them, so be careful...
I've had them on several cars and like them, but they have some drawbacks, like: The steel braid can internally chafe, they stainless housing will chafe other things. You can't see damage to the hose until it's too late, etc.
Basically there are a bunch of opinions on the subject, so do what you want, but I'd hardly call them a "requirement".
