Flashing OD light
Flashing OD light
Last weekend I went to a touristic place that is located about 250 km away from home, when I arrived to the place there are a real up and downhills and the truck first started to have hard shifts (shudder), more between 1st and 2nd. In the downhills I press the overdrive button to help with stopping, and the light began to flash intermittently, I have the interceptor scan gauge, BUT I forgot how to get codes, so I couldn’t get any codes.When I returned home the only problem were the hard shifts and the light flashing but no problem going uphill. That continue till yesterday, when the light went out and the shifts come better than ever before. So what are your opinions about that?. The transmission temperatures where normal and the fluid is ok in color and smell and no too much kms on it. Thanks for your input.
If the light was flashing, there should be a stored transmission code. I'm not sure if the AF Interceptor can pull trans codes or not (perhaps someone else can chime in on that). I think you'll want to get those codes so you know what is going on with the transmission.
Thanks for the input.
When the OD light is flashing the transmission is in limp mode. It will throw full line pressure for shifts, so it will shift really hard. In my experience most inexpensive code readers will not pull up transmission codes on our trucks. MIne did the same thing towing one day, the torque converter was slipping.
Going from memory - Press both buttons on the Interceptor at the same time. You'll see a menu. Move down through the menu items by pressing the left button. Look for "GET DTC". It may be on the second page; just keep pressing Left until it scrolls down and jumps to the next page. When GET DTC is highlighted, press the RIGHT button. That actually executes it. The tiny display has no room for anything verbose, so you should see just the P-code(s) or T-code(s) or whatever one of those "Eeek, for oh dear!" contraptions throws.
P0340: CMP Sensor Circuit Malfunction
P1728: P1728 Transmission Slip Error
Notes: - I haven noted any issues related to the malfunction of CMP
- About the Slip Error means TQ slipping or could slip any other stuff of the tranny?.
Now the question is what to do? As I mentioned above the tranny is working better than ever.
Anyway where is Mark K?
Out making a living.
An error much too small for someone to notice will cause problems with the PCM and set a code.
It could be most of the clutches in the torque converter or the transmission.
The first thing to do is fix the CMP issue and see if that also fixes the slip error code.
Until the next time the CEL is on or the OD OFF is flashin.
You can look at the front face of the torque converter. If the housing is blued, it's been overheated by a slipping torque converter clutch. That's the only thing I know of to check without removing the transmission and tearing it down.
Yes, but the problem could be in the wiring to the CMP.
It doesn't matter. It actually doesn't matter if you clear the codes or not. If you don't clear the codes they will eventually clear themselves IF the problem is solved.
CMOS
12-13-2008 09:18 PM
reitman
16
09-26-2007 01:23 PM
