extra wire by OBDII plug
Sticker on it's says it's for power take off or something. I know there's another wire that looks similar under there around same area that's labeled customer access and is a 10amp switched feed.
you might check your fuses. For some reason my memory thinks the obd port is on the same fuse as one of the front power ports...
The 'extra wire" is completely normal. Read the factory tag.
Cigar lighter plug.
It's pretty common for folks to plug accessories in and blow the fuse. This will keep any scan tool that requires vehicle-provided power from working, it just won't power up.
You will need to check your device's specifications and see if it actually has the needed functionality or not.
the Goat
1999 to 2016 Super Duty
11-02-2007 01:29 PM
