Camper package
Camper package
When try to configure my unicorn super duty yesterday the sales guy told me that I had to get 20 inch wheels etc with a 3.55 locking rear axle.
Unless I got the camper package which is only 140 bucks. But he couldn't figure out what that is...
so what is the camper package?
From the SD Order Guide, pages 30 and 31:
OR
The 20" wheel and tire exclusions looks odd (to me) because the 2017 RV and Trailer Towing Guide (page 12) indicates 20" wheels and tires are available with the CP option.
HTH,
Jim / crewzer
CAMPER PACKAGE (471)
Availability:
Guide should be consulted for specific Trailer Towing or
camper limits and corresponding required equipment,
axle ratios and model availability.
Availability:
● Optional on all Pickups
Not available with: ● 20" Wheels and Tires, Pickup Box Delete (66D), 3.31 Axle Ratio (on 4x4 w/17" or 18" tires) or Heavy-Service Front Suspension Package (67H)
Includes: ● Extra heavy-service front springs (4x2) (2 up upgrade above the spring computer selected as a consequence of options chosen. Not included if maximum springs have been computer selected as standard equipment)
● Heavy-service front springs (4x4) (1 up upgrade above the spring computer selected as a consequence of options chosen. Not included if maximum springs have been computer selected as standard equipment)
● Rear auxiliary springs (F-250 only; Std. on 350)
● Rear stabilizer bar (SRW only)
● Slide-in camper certification
NOTE: Salesperson's Source Book or Ford RV Trailer Towing● Heavy-service front springs (4x4) (1 up upgrade above the spring computer selected as a consequence of options chosen. Not included if maximum springs have been computer selected as standard equipment)
SNOWPLOW/CAMPER PACKAGE (47B)
Availability:
axle ratios and model availability. Restrictions apply; see
Supplemental Reference or Body Builders Layout Book
for details
Availability:
● Optional on XL, XLT, Lariat, and King Ranch®
● 3.31 Axle Ratio (on 4x4 w/17" or 18" tires)
● Heavy-Service Front Suspension Package (67H)
● Heavy-Service Package for Pickup Box Delete (63R)
● Pickup Box Delete (66D)
Requires:● 3.31 Axle Ratio (on 4x4 w/17" or 18" tires)
● 4x4
Includes: ● Computer selected springs for snowplow application
● Extra Heavy-Duty Alternator (67D)
NOTE: Salesperson's Source Book or Ford RV Trailer Towing● Extra Heavy-Duty Alternator (67D)
for details
HTH,
Jim / crewzer
Correct, payload is based off the GVWR- weight of truck. The F250 has a GVWR of 10,000lbs - 7500lb truck = 2500lb payload. The GVWR never changes for the truck so the more options and bigger cab you get the less payload you can carry according to the sticker
True. Ironically, the Camper Package decreases the 250's payload by around 75lbs. That's the weight of the aux springs and sway bar.
lsaunders113
1999 to 2016 Super Duty
09-10-2011 12:58 PM
