camper package vs heavy service suspension package??
can any1 tell me if the rear stabilizer bar comes with the heavy service suspension package on the 11 f350srw?? about ready 2 buy 1 and would like to know cuz i have a 36ft travel trailer and i TRY 2 pull it with my 08 f250 and it does not have the rear stabilizer bar and sways all over the road when i tow my camper. found a new 11 350 with the 6.2 and it does not have the camper package but the heavy suty service suspension.
Heavy service is specific to the front axle only, no rear anti sway (but it can be added). If the truck is everything you need without the anti sway, have the dealer throw it in for you (or do a test pull with your trailer and determine if you even need it).
EDIT - didn't realize the OP was from June, oh well...
Details of both packages from the order guide below:
CAMPER PACKAGE (471)
Availability:
• Optional on all Pickups
Not available with:
• 20" Wheels and Tires, Pickup Box Delete (66D), 3.31 Axle Ratio
(on 4x4 with 17" or 18" tires) or Heavy-Service Front Suspension
Package (67H)
Includes:
• Extra heavy-service front springs (4x2) (2 up upgrade above the
spring computer selected as a consequence of options chosen. Not
incl. if maximum springs have been computer selected as standard
equipment)
• Heavy-service front springs (4x4) (1 up upgrade above the spring
computer selected as a consequence of options chosen. Not incl. if
equipment)
• Rear stabilizer bar (SRW only)
• Slide-in camper certification
• Rear auxiliary springs (F-250 only)
NOTE: Salesperson's Source Book or Ford RV Trailer Towing
Guide should be consulted for specific Trailer Towing or
camper limits and corresponding req. equipment, axle
ratios and model availability
HEAVY-SERVICE FRONT SUSPENSION PACKAGE (67H)
Availability:
• Optional on all pickups
Usage:
• Recommended only on vehicles which will permanently utilize
aftermarket equipment such as Heavy-Duty winches, brush guards
or other apparatus which loads the front axle to the specified Gross
Axle Weight Rating (GAWR)
Not available with:
• Snow Plow Package (473), Camper Package (471) or Heavy-
Service Package for Pickup Box Delete (63R)
Includes:
• Heavy-service front springs (1 up upgrade above the spring
equipment)
NOTE 1: May result in deterioration of ride quality.
NOTE 2: Vehicle ride height will increase w/the addition of this
package.
Availability:
Not available with:
Package (67H)
Includes:
equipment)
equipment)
Availability:
Usage:
Not available with:
Includes:
equipment)
package.
