Camper package
Old May 28, 2017 | 10:02 AM
Chris Crews's Avatar
Chris Crews
Camper package
When try to configure my unicorn super duty yesterday the sales guy told me that I had to get 20 inch wheels etc with a 3.55 locking rear axle.
Unless I got the camper package which is only 140 bucks. But he couldn't figure out what that is...
so what is the camper package?
Old May 28, 2017 | 10:24 AM
crewzer's Avatar
crewzer
Lightbulb
From the SD Order Guide, pages 30 and 31:
CAMPER PACKAGE (471)
Availability:
● Optional on all Pickups
Not available with:
● 20" Wheels and Tires, Pickup Box Delete (66D), 3.31 Axle Ratio (on 4x4 w/17" or 18" tires) or Heavy-Service Front Suspension Package (67H)
Includes:
● Extra heavy-service front springs (4x2) (2 up upgrade above the spring computer selected as a consequence of options chosen. Not included if maximum springs have been computer selected as standard equipment)
● Heavy-service front springs (4x4) (1 up upgrade above the spring computer selected as a consequence of options chosen. Not included if maximum springs have been computer selected as standard equipment)
● Rear auxiliary springs (F-250 only; Std. on 350)
● Rear stabilizer bar (SRW only)
● Slide-in camper certification
NOTE: Salesperson's Source Book or Ford RV Trailer Towing
Guide should be consulted for specific Trailer Towing or
camper limits and corresponding required equipment,
axle ratios and model availability.
OR
SNOWPLOW/CAMPER PACKAGE (47B)
Availability:
● Optional on XL, XLT, Lariat, and King Ranch®
Not available with:
● 3.31 Axle Ratio (on 4x4 w/17" or 18" tires)
● Heavy-Service Front Suspension Package (67H)
● Heavy-Service Package for Pickup Box Delete (63R)
● Pickup Box Delete (66D)
Requires:
● 4x4
Includes:
● Computer selected springs for snowplow application
● Extra Heavy-Duty Alternator (67D)
axle ratios and model availability. Restrictions apply; see
Supplemental Reference or Body Builders Layout Book
for details
The 20" wheel and tire exclusions looks odd (to me) because the 2017 RV and Trailer Towing Guide (page 12) indicates 20" wheels and tires are available with the CP option.
HTH,
Jim / crewzer
Old May 28, 2017 | 11:21 AM
No1Hookman's Avatar
No1Hookman
Since the 20s started showing up in '06, they have NOT been available with the camper package. Doesn't make a whole lot of sense, but that's how they roll.
Old May 28, 2017 | 01:15 PM
nbayless36's Avatar
nbayless36
I screwed up and ordered just the heavy service front Suspension on my 250. How much does the aux springs add to the payload rated?
Old May 28, 2017 | 01:22 PM
LCR's Avatar
LCR
Zero
Old May 28, 2017 | 01:25 PM
nbayless36's Avatar
nbayless36
Originally Posted by LCR
Zero
really? You'd think it would be at least a couple hundred lbs. Guess it just makes the suspension more progressive? And the cert. Of course
Old May 28, 2017 | 01:31 PM
LCR's Avatar
LCR
Correct, payload is based off the GVWR- weight of truck. The F250 has a GVWR of 10,000lbs - 7500lb truck = 2500lb payload. The GVWR never changes for the truck so the more options and bigger cab you get the less payload you can carry according to the sticker
Old May 28, 2017 | 06:15 PM
spud57's Avatar
spud57
True. Ironically, the Camper Package decreases the 250's payload by around 75lbs. That's the weight of the aux springs and sway bar.
treedriver
Mar 15, 2016 09:27 AM
lsaunders113
Sep 10, 2011 12:58 PM
kabur66
6.7L Power Stroke Diesel
Jul 24, 2011 07:27 PM
bigseadaddy
Modular V10 (6.8l)
13
Mar 4, 2009 09:30 AM
atlasman
Sep 27, 2007 08:25 PM
