1978 - 1996 Big Bronco
What did you do to the Bronco Today?
Old 09-15-2017, 08:52 PM
walter white's Avatar
walter white
walter white is offline
Originally Posted by MadMatt65
Sorry for the slow reply. Been without power and phones since the hurricane rolled thru here! The seats came out of a 90's plain jane Bronco. Definitely not as much padding as my XLT seats! Gonna keep them in there till I get my seats redone. For the money, they were a good buy!
Thanks
glad you are ok and back on line
  #3317
Old 10-03-2017, 10:54 PM
ZombieSlayer's Avatar
ZombieSlayer
ZombieSlayer is offline
Swapped out the starter today, 3 days ago it just finally gave out. No amount of beating on it would get it to start again Slowly but surely she's falling apart
  #3318
Old 10-04-2017, 12:03 AM
grumpin's Avatar
grumpin
grumpin is offline
We had a Suburban that I nursed home (almost 300 miles) by not shutting it off or hitting the starter after I got someone to turn the key.
My Bronco starter quit last winter, figured I would hit the starter to move it to a better, dryer spot, no dice.
  #3319
Old 10-04-2017, 11:52 PM
ZombieSlayer
We opened the old starter on the parts counter to see what it looked like (the girl and I had never seen the guts before) and it looks like I busted one of the magnets when I banged on it
The brushes were toast, smelled real bad when we cracked it open and was really black inside.
Left the phone in the Bronco (actually it fell out of my pocket and landed under it) so no pics
  #3320
Old 10-05-2017, 08:18 AM
Avitech's Avatar
Avitech
Avitech is offline
I bought it. The seller was asking 2k and I got it for 900.
This rig will continue to move snow (but only in our driveway), and slowly get the cancer repaired. Might see a few upgrades along the way....
  #3321
Old 10-06-2017, 08:42 PM
phillips91's Avatar
phillips91
phillips91 is offline
Interior still looks good in it too. Hard to find one without the dash pad cracked too. Congrats on the new purchase!
  #3322
Old 10-12-2017, 09:27 PM
Bruners4's Avatar
Bruners4
Bruners4 is offline
I've done a bunch of work over the last few weeks. I'll try to list it all out.
New SS Brake Lines, New brake hoses, New Master Cylinder, New rear wheel cylinders, New calipers, New rear drums & brake shoes & hardware, New drilled and slotted rotors & pads.
New Front driveshaft U-Joints, New front axle U-Joints, New ball joints, New Poly axle pivot bushings, New poly radius arm bushings.
Cleaned and repacked front wheel bearings with all new seals. New rear axle seals, New Ford Racing LSD carbon clutches.
New rear tail lights with retro-fit LED bulbs, LED bulbs in high mount brake/cargo light.
After the front end alignment and seating in the new brakes, I'm just about ready for the winter season.
  #3323
Old 10-13-2017, 06:04 AM
gatorfor88's Avatar
gatorfor88
gatorfor88 is offline
Gave it away.
  #3324
Old 10-13-2017, 12:38 PM
MadMatt65's Avatar
MadMatt65
MadMatt65 is offline
New headlights! Was driving a while back at night, and thought, man....I can't see anything!!
Diamond Eyes from LMR.
Also had to put in a new radiator a couple days ago!
Old and nasty!
Out with the old!
Diamond Eyes!
In with the new!! Definitely an improvement!!
  #3325
Old 10-14-2017, 12:01 AM
grumpin's Avatar
grumpin
grumpin is offline
Good to know MadMatt65! I cleaned mine up with one of those kits and it definitely helped.
But my pass. side is getting moisture in it. I'll have to look into these.
Thanks!
  #3326
Old 12-12-2017, 01:54 AM
khadma's Avatar
khadma
khadma is offline
Carpenter Local 745
New tires and wheels.
  #3327
Old 12-13-2017, 08:23 PM
Bruners4's Avatar
Bruners4
Bruners4 is offline
Changed out the old steering gearbox for a fresh Redhead from Broncoair. Steers like a new truck. Also added a drain plug to the front differential housing.
  #3328
Old 12-13-2017, 10:28 PM
diymirage's Avatar
diymirage
diymirage is offline
put her to work
  #3329
Old 12-13-2017, 10:53 PM
ZombieSlayer
Wasn't done today but yesterday, put in another replacement starter. The reman Motorcraft I got was bad So hopefully this one isn't On the plus side I'm getting pretty quick at swapping out starters
  #3330
Old 12-15-2017, 03:30 PM
Locoforfomoco's Avatar
Locoforfomoco
Locoforfomoco is offline
A week or so ago I switched out the old rims and tires for some old junkyard rims I cleaned up and some new tires. Also new is the front u-joints and shaft bearings. I also fixed my stereo ground wire today. Now, I can crank tunes again. She's finally coming together from an old derelict POS.
Quick Reply: What did you do to the Bronco Today?
