What did you do to the Bronco Today? - Page 222 - Ford Truck Enthusiasts Forums
1978 - 1996 Big Bronco
  #3316
Old 09-15-2017, 09:52 PM
walter white walter white is offline
walter white is starting off with a positive reputation.
Quote:
Originally Posted by MadMatt65 View Post
Sorry for the slow reply. Been without power and phones since the hurricane rolled thru here! The seats came out of a 90's plain jane Bronco. Definitely not as much padding as my XLT seats! Gonna keep them in there till I get my seats redone. For the money, they were a good buy!
Thanks
glad you are ok and back on line
  #3317
Old 10-03-2017, 11:54 PM
ZombieSlayer's Avatar
ZombieSlayer ZombieSlayer is online now
ZombieSlayer has a good reputation on FTE.ZombieSlayer has a good reputation on FTE.
Swapped out the starter today, 3 days ago it just finally gave out. No amount of beating on it would get it to start again Slowly but surely she's falling apart
  #3318
Old 10-04-2017, 01:03 AM
grumpin's Avatar
grumpin grumpin is offline
grumpin is gaining momentum as a positive member of FTE.
Quote:
We had a Suburban that I nursed home (almost 300 miles) by not shutting it off or hitting the starter after I got someone to turn the key.
My Bronco starter quit last winter, figured I would hit the starter to move it to a better, dryer spot, no dice.
  #3319
Old 10-05-2017, 12:52 AM
We opened the old starter on the parts counter to see what it looked like (the girl and I had never seen the guts before) and it looks like I busted one of the magnets when I banged on it
The brushes were toast, smelled real bad when we cracked it open and was really black inside.
Left the phone in the Bronco (actually it fell out of my pocket and landed under it) so no pics
  #3320
Old 10-05-2017, 09:18 AM
Avitech Avitech is offline
Avitech is starting off with a positive reputation.
I bought it. The seller was asking 2k and I got it for 900.
This rig will continue to move snow (but only in our driveway), and slowly get the cancer repaired. Might see a few upgrades along the way....
  #3321
Old 10-06-2017, 09:42 PM
phillips91 phillips91 is offline
phillips91 has much to be proud ofphillips91 has much to be proud ofphillips91 has much to be proud ofphillips91 has much to be proud ofphillips91 has much to be proud ofphillips91 has much to be proud ofphillips91 has much to be proud ofphillips91 has much to be proud ofphillips91 has much to be proud of
Interior still looks good in it too. Hard to find one without the dash pad cracked too. Congrats on the new purchase!
  #3322
Old 10-12-2017, 10:27 PM
Bruners4's Avatar
Bruners4 Bruners4 is offline
Bruners4 is gaining momentum as a positive member of FTE.
I've done a bunch of work over the last few weeks. I'll try to list it all out.
New SS Brake Lines, New brake hoses, New Master Cylinder, New rear wheel cylinders, New calipers, New rear drums & brake shoes & hardware, New drilled and slotted rotors & pads.
New Front driveshaft U-Joints, New front axle U-Joints, New ball joints, New Poly axle pivot bushings, New poly radius arm bushings.
Cleaned and repacked front wheel bearings with all new seals. New rear axle seals, New Ford Racing LSD carbon clutches.
New rear tail lights with retro-fit LED bulbs, LED bulbs in high mount brake/cargo light.
After the front end alignment and seating in the new brakes, I'm just about ready for the winter season.
  #3323
Old 10-13-2017, 07:04 AM
gatorfor88's Avatar
gatorfor88 gatorfor88 is offline
gatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputationgatorfor88 has a superb reputation
Gave it away.
  #3324
Old 10-13-2017, 01:38 PM
MadMatt65's Avatar
MadMatt65 MadMatt65 is offline
MadMatt65 has a good reputation on FTE.MadMatt65 has a good reputation on FTE.MadMatt65 has a good reputation on FTE.
New headlights! Was driving a while back at night, and thought, man....I can't see anything!!
Diamond Eyes from LMR.
Also had to put in a new radiator a couple days ago!
Old and nasty!
Out with the old!
Diamond Eyes!
In with the new!! Definitely an improvement!!
  #3325
Old 10-14-2017, 01:01 AM
grumpin's Avatar
Good to know MadMatt65! I cleaned mine up with one of those kits and it definitely helped.
But my pass. side is getting moisture in it. I'll have to look into these.
Thanks!
  #3326
Old 12-12-2017, 02:54 AM
khadma's Avatar
khadma khadma is offline
Carpenter Local 745
khadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud of
New tires and wheels.
  #3327
Old 12-13-2017, 09:23 PM
Bruners4's Avatar
Changed out the old steering gearbox for a fresh Redhead from Broncoair. Steers like a new truck. Also added a drain plug to the front differential housing.
  #3328
Old 12-13-2017, 11:28 PM
diymirage diymirage is offline
diymirage is starting off with a positive reputation.
put her to work
  #3329
Old 12-13-2017, 11:53 PM
Wasn't done today but yesterday, put in another replacement starter. The reman Motorcraft I got was bad So hopefully this one isn't On the plus side I'm getting pretty quick at swapping out starters
  #3330
Old 12-15-2017, 04:30 PM
Locoforfomoco's Avatar
Locoforfomoco Locoforfomoco is offline
Locoforfomoco is starting off with a positive reputation.
A week or so ago I switched out the old rims and tires for some old junkyard rims I cleaned up and some new tires. Also new is the front u-joints and shaft bearings. I also fixed my stereo ground wire today. Now, I can crank tunes again. She's finally coming together from an old derelict POS.
What did you do to your Super Duty today? ufvj217 1999 to 2016 Super Duty 1063 02-20-2018 10:55 PM
What would make the best family hauler fun rig? F350moneypit 1973 - 1979 F-100 & Larger F-Series Trucks 25 01-03-2018 02:11 PM
Why did you pick a Bronco? greystreak92 1978 - 1996 Big Bronco 128 01-02-2018 07:44 PM
My 95 bronco idi build Jay54 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 21 05-08-2017 04:07 AM
Project Thunderhorn: Second Generation Bronco Build Thunderhorn 1978 - 1996 Big Bronco 68 02-06-2017 02:19 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
