Egr????
Old Feb 10, 2003 | 09:35 AM
Hookie's Avatar
Hookie
Question Egr????
How about posting some picsof your EGR restrictor, blockoff or how ever you have moded it..............
I just unhooked the vacume from mine. 96 model...
Old Feb 10, 2003 | 02:48 PM
stractor's Avatar
stractor
Egr????
There is nothing to post. Get an EGR valve gasket and make a metal copy and only punch out the two bolt holes. It is nothing more than a metal block off plate, make it the same shape as the gasket and leave out the big holes. You will need two gaskets one for each side of the plate.
stractor
Old Feb 11, 2003 | 07:29 AM
GNORMOR's Avatar
GNORMOR
Egr????
Nothing to it Use the new gaskets as a temtplate. I use 1 of the new wife's pie plate and a set of tin snips. I would not use anything much thinner then a pie plate. Word of warning!!!! Don't get caught using wife's kitchen stuff, They get a little bent out of shape. It is well woth the effort to block the EGR!
GNORMOR
Old Feb 11, 2003 | 12:52 PM
jrs_big_ford_f150's Avatar
jrs_big_ford_f150
Egr????
I used my empty beer can and two gaskets.
Old Feb 11, 2003 | 04:48 PM
motobub's Avatar
motobub
Egr????
Where is the EGR on my truck? It is an 88 300 with efi. It sounds simple enough, but where is it on the engine?
Thanks in advance
Lars
Old Feb 11, 2003 | 07:26 PM
Hookie's Avatar
Hookie
Egr????
How about just unhooking the vacuum from the Egr??? Wouldn't that do the same as a blockoff plate??????
Old Feb 11, 2003 | 08:45 PM
MEPR's Avatar
MEPR
Egr????
I have an 82 and have thought about blocking or pulling my egr but i have heard about the motor blowing the #3 cylinder in some of em. Any body have probs whith this or any knocking?
Old Feb 11, 2003 | 08:59 PM
tetraruby's Avatar
tetraruby
Egr????
Pulling the vacuum line works fine on older carbed trucks that are not dependant on some sort of signal generated by the movement of the valve itself (like my old '79)....I think the FI motors require the valve to move as to keep the computer thinking it's operating...someone with a FI motor pipe in here...
Old Feb 11, 2003 | 10:04 PM
stractor's Avatar
stractor
Egr????
If you disconect the vac line to the EGR valve on an FI engine you will set a code in the computer and set off the check engine light.
stractor
Old Feb 12, 2003 | 09:00 PM
Hookie's Avatar
Hookie
Egr????
stractor
I unhooked the vacuum line going to the EGR a couple weeks ago and NO codes as of yet... What do you guys think???
96 f-150
Old Feb 15, 2003 | 06:02 PM
Martys82's Avatar
Martys82
Egr????
i have a 82 i6 would blocking it be good for me?
Old Feb 16, 2003 | 07:42 AM
wilddog's Avatar
wilddog
Egr????
I pulled the line off the EGR before I found out about the resticter plate. It did cause the engine light to come on, but worse the gas milage dropped to something like 10-12. Put the plate on, it's by far the best and cheapest thing I ever did with this truck. Runs better than it did when new and gets 19-20 mpg on the highway.
F-150, 4.9,4x4
mrwrench
Feb 9, 2012 12:55 PM
TEXFARLEY
Apr 13, 2011 10:09 AM
bigmacmonday
Feb 1, 2010 10:47 AM
dantsg
1997 - 2003 F150
Apr 26, 2009 04:59 PM
shaunone
Oct 12, 2006 06:55 PM
