A few auto tranny questions
Old Feb 4, 2010 | 10:29 AM
64F260's Avatar
64F260
I am buying a 2000 F250 with auto tranny. It seems to shift ok, no SES light, fluid smelled ok. Only thing is it has 210,000 miles. Truck is all stock, no chip, original exhaust and intake. I think this truck was well cared for. If I am on top of fluid changes, and maybe install a 6.0 tranny cooler, and a trans temp gauge, is it realistic to get 300,000 or more from the tranny? I will not be doing much towing. Any other tips on how to get the most out of the tranny?
Old Feb 4, 2010 | 10:33 AM
Pocket's Avatar
Pocket
The 300,000 mile transmission is a rare bird.
Are you positive the trans hasn't been rebuilt already?
As for longevity, it seems the stock trans lasts longest when you leave the truck absolutely bone stock, don't tow heavy with it, and put a lot of highway miles on it. At any rate, it's always a gamble. Keep servicing and maintaining the engine and trans, and cross your fingers when it comes to the transmission.
Old Feb 4, 2010 | 10:42 AM
64F260's Avatar
64F260
Ok, thanks. The deal was so good, I have "built in" the cost of tranny just in case. It could have been replaced. The original owner had it till Dec. 08, he worked at a dealership in Colorado. Second owner had it for a little over a year, and wants a car for better mileage. Are there any pointers that might show if tranny was replaced?
Old Feb 4, 2010 | 10:50 AM
mueckster's Avatar
mueckster
Check the build date on the trans tag. It would most likely be different from the truck build date if it has been replaced. IIRC, usually the trans and truck build dates are within a month of each other. That still wouldn't tell you if the original had been rebuilt though, unless there was some sort of stamp or tag on it.
Old Feb 4, 2010 | 10:58 AM
64F260's Avatar
64F260
Thanks, good idea. Would one of those oil analysis samples show anything? I've heard of guys doing it on the trans fluid.
Old Feb 4, 2010 | 11:26 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
In 2000 those trucks were selling so fast the trans build date was usually the same DAY as the truck build date! The assembly line at KTP (where the trucks are built) would be assembling transmissions to engines where the trans was still warm from it's final test at the transmission plant.
Old Feb 4, 2010 | 11:30 AM
pwrtrip's Avatar
pwrtrip
It still wouldnt hurt to install the gauge and cooler for piece of mind.
Old Feb 4, 2010 | 11:31 AM
clem1226's Avatar
clem1226
since the original owner worked at the dealer is it possible he would have replaced the tranny there? (if it was replaced), would an OASIS show this?
I think an oasis would be a good idea at any rate.
Good luck
Old Feb 4, 2010 | 11:32 AM
Izzy351's Avatar
Izzy351
Wow! That's amazing!!
Old Feb 4, 2010 | 02:22 PM
farmb0y's Avatar
farmb0y
Glad you have the cost of a new tranny built in. But being bone stock, I would think it'd go for quite a while yet. I bought my truck at 103k miles and put on another 120k or so with mods and towing and working hard before it let go. You're on the right track with the tranny cooler and gauges.
Old Feb 5, 2010 | 08:59 AM
koski19's Avatar
koski19
I have an early 99 with the 4R100. This tranny has 232,000 miles on it. The previous owner stated no work was done on the tranny nor was it rebuilt. I bought the truck used. When I first completed the trans service, I had Balckstone do the analysis.
The readings were at cautionary levels. Since then, I have completed 3 additional tranny services which included the filter and a magafine filter which in my case, went 20,000 miles. The fluid readings have dropped considerably and I'm now on a 30,000/40,000 fluid change interval. I now run Mercon V. Maintenance is the key. I would service the tranny, 20 qts mercon V, a Magafine filter and an interal filter. Send an oil sample to whomever and see the results and recommendations. Then go from there. My first sample I estimated had 30,000 + on the oil, then I went 9911, 11,514 and 20,512 miles.
The iron content dropped from 289 to 72, Copper dropped from 95 to 24,
Silcon dropped from 24 to 9...I tow a two horse trailer and a cabover camper serveral times a year. Hope this helps in your decision. I think you could get 300,000 out of a trans with proper maintenance. Fluid and filters are cheap.
Old Feb 5, 2010 | 11:03 AM
parkland's Avatar
parkland
I think it might be time to change my tranny fluid/ filter......300,000km's on it, never done yet...
fsckedagain
17
Dec 20, 2024 12:10 PM
nextalcupfan
Apr 11, 2013 08:55 AM
GTBksRule
Jan 29, 2013 12:27 PM
teddeshong
Apr 30, 2011 02:11 AM
fixitman1310
Apr 19, 2011 07:46 PM
