tranny question
Old Apr 10, 2011 | 06:52 PM
fixitman1310's Avatar
fixitman1310
Question tranny question
hey guys i just got this truck. 95 f350 ps auto e4od 274,000 miles
the speedometer went out and no odometer and the od light started
flashing and tranny went into limp mode. i replaced the instrument
cluster first and it worked. i reset all codes with computer and od
light stopped flashing . tranny seems to be ok, shifting good.
will the tranny go into limp mode if speedometer quits.
thanks guys
steve n.carolina
Old Apr 11, 2011 | 12:10 AM
JamesHajek's Avatar
JamesHajek
I think the VSS going out will affect it.
Old Apr 11, 2011 | 12:15 AM
BuckHammer's Avatar
BuckHammer
An E4OD will not function properly without a vehicle speed sensor.
Old Apr 11, 2011 | 12:20 AM
JamesHajek's Avatar
JamesHajek
If you have a code reader, Grab the code... When the OD light flashes, a code is stored.
Old Apr 11, 2011 | 05:28 AM
fixitman1310
no tranny code kam code
i did not get a slippage code or any transmission codes.
i got a memory code. i reset it. i cleaned the speed sensor
and re installed it. should i replace it?
thanks again
steve
Old Apr 11, 2011 | 07:18 AM
MADVAN's Avatar
MADVAN
Clearing the pcm is what took the trans out of limp.
If the issue was in the psom and you changed it you should be good to go.
If it was not the psom that its just a matter of time before the trans limps again.
Bill
Old Apr 19, 2011 | 05:14 PM
97XLT4X4's Avatar
97XLT4X4
wheres this vehicle speed sensor? my speedometer flucuates once over 40 mph
Old Apr 19, 2011 | 07:46 PM
fordpride's Avatar
fordpride
On the top of the rearend
umpalumpa1985
17
Oct 17, 2022 01:12 PM
351w5.8
New Member Introductions
Jul 14, 2016 07:47 PM
lilhelppls
1997 - 2003 F150
Apr 21, 2015 01:21 PM
rungunner
45
Jun 12, 2012 07:21 AM
juggalo555
Feb 1, 2012 10:30 AM
