1989 f150 ttb
Old Jan 11, 2010 | 08:28 PM
jake_599's Avatar
jake_599
1989 f150 ttb
hey guys had a question i have a 89 f150 and for the past year ive been having clucking and popping from my front axle sometimes right before i stop some when i turn or take off i did notice that my D-side axle moves up/down and side to side a lot more then the other side can some one tell me what this is please, (when im in 4wd for a long time it will start grinding or if i leave the hubs locked in for awhile afterwords)
Old Jan 11, 2010 | 09:30 PM
fordman1090's Avatar
fordman1090
When you say that the axle is moving around alot, are you talking about the entire axle housing and wheel. Or just the axle shaft?
If its the entire housing housing then maybe the shocks and bushing are worn and its just loose.
If its just the axle shaft it may be the u-joint is shot and the spindle and center section axle bearings have failed because of it.
Good Luck
Old Jan 11, 2010 | 10:21 PM
fishforlife2007's Avatar
fishforlife2007
there is a bushing in the middle of the ttb. im a little unclear with wat your trying to say.
Old Jan 11, 2010 | 11:09 PM
fordman1090
fish:
Me or the OP?
i was talking about severely worn pivot, radius arm and shock bushings causing alot of play in the whole axle housing assembly allowing it to move from front to back, as well as making the clunking sounds.
We defiantly need a little more info on what exactly is happening.
Old Jan 11, 2010 | 11:56 PM
jake_599's Avatar
jake_599
sorry i mean just the axle shaft Ive checked to see if the wheel makes any popping or type of symptoms of being loose/worn out and it docent.
Old Jan 12, 2010 | 11:30 AM
fordman1090
If its the axle shaft then its probably the u-joint. And because its so lose it may have trashed some bearings, but you wont know until its all apart. And its not really all that hard to do either.
Old Jan 12, 2010 | 07:37 PM
jake_599's Avatar
jake_599
what do you think the coast would be around i figured i might probably need a new hub and stuff...
Old Jan 12, 2010 | 09:21 PM
fordman1090
It really depends on how much damage and where you get the parts. You could find a locking hub that matches yours at a junkyard for rather cheap. Or you could replace both with new manuals hubs for around $100, plus $30 for the 1 u-joint, $30 for the new axle bearings and seals. And youll need some special tools, including the socket for the 4 prong spindle nut, and a blind hole puller/slide hammer.
Old Jan 17, 2010 | 01:58 PM
jake_599's Avatar
jake_599
well when i got the truck it had one stock hub (d-side) and a warn on the other side idk why it wasn't just both warn hubs soo is it a pain to change that u-joint
wkp
2004 - 2008 F150
Feb 7, 2013 05:13 PM
changoo
Nov 11, 2010 01:20 AM
DarkNite
Oct 20, 2009 11:26 AM
Boss300
Mar 15, 2002 04:45 PM
cma
Apr 30, 2001 07:24 PM
