Anyone try t/p springs
Old May 15, 2008 | 05:04 PM
famfun's Avatar
famfun
this is for a v10,
t for front not much stiffer then stock? but don't know the spring rate of the p's??
anyone?
thanks roger
Old May 16, 2008 | 08:07 AM
housedad's Avatar
housedad
I see noone has answered this one. I guess not many have thought about it.
I did exhaustive searching on this and other websites for information about the T code springs.
One person about 4 years ago indicated in a post that they were going to install the T codes, but there was no further response from them.
The T codes sound good to be able to have the soft front ride like the original springs, but the real problem is that no one has seen a T code to be able to measure and confirm the amount of arch. Any estimates that have been made regarding how much lift the T codes will give are an assumption that the T codes have the same rate of arch as all the other superduty springs.
I don't think this is the case, though. A couple of years ago, I saw a 2004 F250 at Home Depot that seemed as if the owner had installed a lowering kit. I inquired and the owner said it was stock. He allowed me to get the numbers off the springs. I took a rubbing, but I have since lost them. Anyway, I took them to my local dealer, and my favorite parts man, Duncan, told me they were T codes.
If the arch is nearly the same as the Excursion original springs, then the whole point of changing springs would be moot. We need a larger arch to get the axle away from the frame and increase spring travel.
At a couple hundred a spring, there hasn't been anyone willing to try it.
Bion Rogers
Last edited by housedad; May 16, 2008 at 08:29 AM. Reason: repaired the formatting
Old May 16, 2008 | 10:20 AM
famfun's Avatar
famfun
Well the impression we are getting it that the p's are b's with overload. The info we are finding leads us to believe that it is the same spring rate as b's. And you can install them with out the overload.
The T's have a higher spring rate then the stock excursion. Comparing the difference between spring rate on the stock PSD EX spring (rate 380) and the v's (410). That is about the same diffence in change as the T( v10 stock 350, to T 390). Am I looking at this wrong? My nieghbors truck has these on it and it sits good and Handles my trailer much better. Have found a set of these springs that came of a 03 when it was new. Worth trying?????
roger
Old May 16, 2008 | 11:57 AM
xr7390GT's Avatar
xr7390GT
U codes work good on V10 Excursions, similar to V on PSD. Never heard of T codes, but you need the extra travel for a better ride.
Old May 18, 2008 | 05:12 PM
famfun's Avatar
famfun
Maybe someone can tell me this, are the rear springs with overload the same rate as the ones with out???
roger
Old May 21, 2008 | 11:06 PM
famfun's Avatar
famfun
Well installed the t & p's. The t's on the front work good. Lift is about 1.25inch. Ride is noticable different, but not harsh like my old(90) f250. Now the P's? Put the trailer on the back to weigh it down and see. Well it just kept going down? My truck goes about 3 inch or so with out bars. Guys that have b rear spring, how much sag do you get. Got these spring cheap ( came off a truck when it was still new ), so may order a new set of b's.
thanks roger
szold
Jul 10, 2019 07:15 PM
jdyal2
Mar 31, 2014 07:27 PM
Hondaonda
Feb 17, 2013 02:05 PM
greenwoodford
Jul 8, 2010 10:10 PM
