2-speed wiper switch question
Old 01-04-2008, 07:45 AM
brider's Avatar
brider
brider is offline
On the 2-speed wiper switches (mine is a '66 with a 1-speed wiper), is the speed control in the SWITCH, or is there a ballast resistor somewhere downstream from the switch?
Old 01-04-2008, 09:19 AM
jowilker's Avatar
jowilker
jowilker is offline
I would say the switch. I swapped both at the same time, then unplugged the switch and plugged in a delay switch.
John
Old 01-04-2008, 09:46 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
1961/66 wiper motors & switches
1961/66 F100/350 = Three different wiper motors: one for single speed motor, and two for 2 speed motors (1966: depends on serial #).
1961/66: C4TZ-17508-G .. Wiper Motor ~ Single Speed (Motorcraft WM-158)
1961/65; 1966 early models ONLY: D0TZ-17508-A .. Wiper Motor ~ Two Speed (Motorcraft WM-150) Use before serial number 788,001
1966; 1967/72: C7TZ-17508-D .. Wiper Motor ~ Two Speed (Motorcraft WM-225) 1966: Use after serial number 788,001
3 different Wiper Switches (sigh)
1961/66 single speed: C3TZ-17A553-G (Motorcraft SW-722) MARKED: C3TB-17A553-G
1961/66 two speed / 1966 = use before serial # 760,001: C3TZ-17A553-E (Motorcraft SW-721) 4 Terminals / MARKED: C3TB-17A553-A or C3TB-17A553-B
1966 Two Speed / use after serial # 760,001: C6TZ-17A553-B (Motorcraft SW-736) 7 terminals / MARKED: C6TB-17A553-B
Old 01-04-2008, 09:52 AM
merlynr's Avatar
merlynr
merlynr is offline
On a 66 Mustang the wiper motor and the switch is different. There doesn't seem to be a resistor externally anywhere, but possibly in the motor. The 2 speed switch has 7 wires including one that goes to washer motor and then back to wiper motor. The single speed sw has 5 wires of which 4 goes to the wiper motor.
Old 01-04-2008, 09:58 AM
brider's Avatar
brider
brider is offline
Thanks and sorry to everyone, but my interest is not in converting to 2-sp wipers (although I am printing all the info and P/N's ND provided), but whether I can use a 2-sp wiper switch as a fan motor switch in another vehicle. I was thinking it would be an easy install if I could retain the 2-sp feature in the switch itself...
Old 01-04-2008, 09:59 AM
NumberDummy
Originally Posted by merlynr
On a 66 Mustang the wiper motor and the switch is different. Four different switches = Single speed: one for w/s washers, one without; Two speed: one with w/s washers, one without. There doesn't seem to be a resistor externally anywhere, but possibly in the motor. The 2 speed switches have 7 wires including one that goes to washer motor and then back to wiper motor. The single speeds have 5 (7 with w/s washers) wires of which 4 goes to the wiper motor.
Ford passenger cars:
1966 before 1/1/1966 = There are two wiper motors = one for single speed / one for 2 speed.
1966 after 1/1/1966 = two speed wiper motors only.
On January 1, 1966, a new Gov't safety standard went into effect for CARS only (E100; F100/350 & Bronco in 1967). Among the changes: 2 speed wipers w/ windshield washers were standard equipment, also standard: a left hand outside mirror, lap seat belts for 4 passengers, backup lights, dual horns, turn signals (!), heater/defroster..etc.
The following users liked this post:
Old 01-04-2008, 01:34 PM
merlynr's Avatar
merlynr
merlynr is offline
That would be doable with the resistor from heater fan control from a Ford heater as they had multiple speed fans controlled by the resistor.
Old 10-27-2014, 12:11 AM
Sam's1967's Avatar
Sam's1967
Sam's1967 is offline
ND, I see that you indicated that C4TZ-17508-G was ised for a 61 through 66 models. How is a part number with a "4" be correct for vehicles prior to 64?
Old 10-27-2014, 05:47 AM
NumberDummy
Originally Posted by Sam's1967
ND, I see that you indicated that C4TZ-17508-G was used for a 61 through 66 models. How is a part number with a "4" be correct for vehicles prior to 64?
FoMoCo is notorious for replacing/updating 10's of 1000's of part numbers EVERY YEAR!
Old 10-27-2014, 11:43 AM
Sam's1967's Avatar
Sam's1967
Good stuff. What part number did the C4TZ-17508-G replace? In other words, what was the 61 to 63 part number? Thanks for your help.
Old 10-27-2014, 10:06 PM
NumberDummy
What part numbers did the C4TZ-17508-G replace? In other words, what were the 61 to 63 part numbers?
C4TZ-17508-G replaced C1TF-17508-B & C3UZ-17508-C
1964FORDTUF
10-05-2016 08:47 AM
WW2N
05-26-2016 08:11 PM
Shadowrider123
12-31-2014 05:05 AM
1972RedNeck
07-18-2012 07:28 AM
Blue and White
01-01-2012 05:34 PM
Quick Reply: 2-speed wiper switch question
