Delay Wiper Switch
Old Jul 17, 2012 | 07:25 PM
1972RedNeck's Avatar
1972RedNeck
Delay Wiper Switch
What does it take to put a delay wiper switch out of a newer truck into my '66? I have the 2 speed switch with a pull for washers.
Old Jul 17, 2012 | 10:07 PM
Broomfieldbum's Avatar
Broomfieldbum
I bought a switch out of a 79, and it works great and bolted right in. You do do need to trim the length to make it look stock. The other thing you need to do is put a motor out of the same year in, but make sure to use your bracket, and wiper arm. If you use the wiper arm from the later year they will not park correctly. I don't know where they park, but that is just what I read.
Mine works great.
Old Jul 17, 2012 | 10:40 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Don't forget the intermittant wiper governor.
Old Jul 17, 2012 | 10:42 PM
1972RedNeck
Why won't my motor work? Does the newer motor have to be made for delay?
Old Jul 17, 2012 | 10:43 PM
1972RedNeck
What is this? Where does it go? How do I wire it in? Where do I get one?
Old Jul 17, 2012 | 11:03 PM
Broomfieldbum
The wiper module is what some people call it, and it just plugs into the switch, and hangs off it behind the dash.
I attached a picture of all the switch and module stuff you need I got the pict off Ebay.
Old Jul 17, 2012 | 11:05 PM
NumberDummy
FoMoCo terminology: Intermittant Wipers / Enthusiasts term: Delay Wipers.
No intermittant wiper governor, no workee intermittant wipers! Some peeps call the governor a "delay module."
The governor (black plastic box*) is located on the firewall adjacent to the wiper motor. There are two types: 1973/77 F100/350 (same as 1971/73 Mustang/Cougar) / 1978/79 F100/350 & Bronco.
The intermittant switch is the same: 1973/79 F100/350, 1978/79 Bronco, 1971 Fairlane/Torino: D1OZ-17A553-A (Motorcraft SW-1010) / Marked: D1OB-17A553-AA
All these parts are obsolete, but can be found NOS. But, intermittant wipers were optional, so not all these F100/350's and Bronco's will have it. Look at XLT's and Lariats, there's more of a chance of finding the setup.
Ask jowilker how he wired his up in his 1966 F100.
* If the (1975/79) vehicle has Speed Control, there will another black box (Speed Control amplifier), located near the fuse box, adjacent to the steering column.
EDIT: Pic in post 6: You will not find a 1973/79 intermittant governor with an ID number of E4TF-17C476-AA ~ Ford part number: E4TZ-17C476-A = 1984/86 F150/350 & Bronco.
Someone (maybe it was jowilker, I'm not sure) said you can use 1980's parts in lieu of 1973/79 parts. BUT...I'm not saying this, it's just something I've read in this forum.
Old Jul 18, 2012 | 03:17 AM
jowilker's Avatar
jowilker
Redneck, Don't know why you are having trouble, everything was plug & play for me. I did like Broomfield sez.
Best I can tell it really doesn't matter where the donor comes from in the Ford family lineup as long as the switch looks similar to the one above. Some were sliders and will work but not in the old wiper spot.
Picked up my parts while out yarding.
John
Old Jul 18, 2012 | 07:28 AM
1972RedNeck
I'm not having trouble yet. I want to avoid trouble when I start the conversion.
Now it's time to go pickin'
1979camperspecial
Nov 30, 2013 01:31 PM
clemjr
Mar 27, 2012 08:08 PM
4byford
Electrical Systems/Wiring
Jan 7, 2007 06:23 PM
wiseguy50
May 12, 2006 05:14 PM
John Pen
1978 - 1996 Big Bronco
Dec 19, 2003 12:50 PM
