Wiper switch and motor
Old Dec 30, 2014 | 01:37 PM
Shadowrider123's Avatar
Shadowrider123
After reading as many threads as I could find I think that I understand this.
If I want to install intermittent wipers on my 64 F100 I need the switch and the corresponding motor off a 70s F series.
I have a 75 parts truck with a good motor, so I would just need to locate the intermittent switch.
Would I then be able to take my 2 speed wipers and switch from the 64 F100 and install them in place of the 1 speed wipers on my 65 Mustang?
If so I could kill two birds for the cost of the intermittent wiper switch.
Old Dec 30, 2014 | 01:50 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
To convert to intermittent (delay) wipers, you'll need a 2 speed wiper motor, intermittent wiper switch and the intermittent wiper governor.
Ask jowilker, he's the expert on all things intermittent.
Old Dec 30, 2014 | 01:56 PM
Shadowrider123
Correct ND, but how about using the 2 speed motor and switch from my 64 F100 in my 65 Mustang?
The Mustang is a 289/AT deluxe interior, but came with single speed wipers.
Old Dec 30, 2014 | 02:01 PM
NumberDummy
The truck wiper motor will not work in the Mustang, neither will the switch.
You cannot use a plain 'ol 2 speed wiper switch to convert to intermittent wipers. You'll need a 2 speed wiper switch specifically for intermittents and will also need the governor.
Old Dec 30, 2014 | 03:07 PM
Shadowrider123
Right ND. I have been looking for the switch and governor. All of them I have found for sale have come together, since one will not work without the other, at least if you want intermittent wipers.
Old Dec 31, 2014 | 05:05 AM
jowilker's Avatar
jowilker
I will leave it to ND to say what will and will not work, he does an excellent job there.
I can revile what I picked up trial & error if you are interested. It appears that many late 70s, 80s & some 90 intermittent switches can be made to work. You will find them in a sliding or rotating control configuration. Since the trucks use rotating switches that is what I went with. Doesn't seem to matter car, truck, van, or other Blue Oval product for the donor. I usually don't look at pre 65 questions, so ND will have to say what is is. I can share what I did in my 1966 F100.
I had bought a 76 F100 donor for my ps/pdb/C6 upgrade. I have no idea today how the conversion started or why I put the 76 wiper motor in my truck. This was 13-14 years ago. I installed the 76 wiper motor, found that it worked but didn't park correctly. I swapped the 66 arm to the back of the motor and walla that worked. I got the switch set from another NC truck owner so I can not say for sure what it came from. The power goes to the motor then to the switch. I plugged in the delay switch set and it worked. It still worked the other day when I fired the truck up after a couple-three months and turned them on to flick the pine needles off.
The switch does come with the control. Get it all if you pull it yourself.
Hope this helps.
John
Marky48170
Aug 24, 2025 04:25 AM
brider
Oct 27, 2014 10:06 PM
Tony_C
Jan 20, 2012 12:10 AM
Cobra6
Dec 22, 2007 04:33 PM
wiseguy50
May 12, 2006 05:14 PM
