I am needing to replace the rear shock absorber mounting studs (#18193) on a 1948 F2. It looks like the stud presses on to the spring seat. I would like to replace the stud on the vehicle without disassembling the springs.
Any ideas on how I can remove the old stud and install a new one? If I drill it out will I be able to hammer a new stud in or will I need a press? Has any body done this and who did you purchase the stud from
Thanks
Frank
I would replace the whole bracket, a little torch heat and the U bolts from the axle mount should loosen up nicely.
I think this is alot easier doing it this way than trying to work underneath a truck (if you can find this used part).
Frank I live in West Palm I have 2 brackets in very good shape and a rear end that can go with it, not sure whats its worth, if your interested make me an offer
Fomoko1 - I really didn't want to remove the bracket, I am ready to get the frame sand blasted as is.. except for the shock mount studs. But yes it is tough to work on that part from under the truck.
I hear you on not wanting to remove the bracket but I don`t know what else to suggest.....Except to try drilling it out and welding a proper sized bolt in, it depends on what you have on hand and available to use. Once you have it out you can take it to a welding shop for repairs. I doubt trying to hammer in a replacement will work out.
I was able to replace that stud by removing the bracket, clamping it in a vice and hammering the stud out with a punch. I was than able to use the vice to press in the new one.
You probably could carefully hammer in the new one under the truck but it won't be easy.....
