a/c
Old Apr 12, 2007 | 05:50 PM
XylemXorro's Avatar
XylemXorro
a/c
I'm sure this is a repeat, so don't be angry ok.
Could someone tell me why my a/c is not that cool when sitting still, but when I'm moving it's cold as heck??? Any simple solution before I go pay a shop boocoo bucks?
Old Apr 12, 2007 | 07:02 PM
Monsta's Avatar
Monsta
Sit. Stay.
Save your money.
Make sure the condensor is free from bugs and stuff. Ther condensor is the radiator looking thing in front of the radiator. If it is clogged up with bugs it can impede the limited airflow provided by the engine's fan. Once moving the forward momentum must overcome any "clogging".
Clean it out by flushing it out from the back. If you spray in the front you only push the stuff in deeper. You may have to remove the stuff to get a good angle of attack. Soak it down with the windshield washer stuff that is said to cut through bug grime or something similar first.
Also make sure your refrigerant is up to the correct pressure/amount.
Old Apr 13, 2007 | 08:09 AM
SLAYER1's Avatar
SLAYER1
My wifes 02 EX does the same thing, at idle vent temp is about 70-75, at hwy speeds i've seen it as low as 37 degrees, i took it to the dealer under factory warranty and they said everything was normal (of course), the condenser is clean, fan clutch maybe?
Old Apr 13, 2007 | 12:29 PM
Monsta's Avatar
Monsta
Sit. Stay.
Probably not anything wrong with the clutch fan. This is just a common problem with our trucks. If nothing is wrong with it then a suggestions to improve it would either be install electric fans or try and find a Syclone fan clutch. Both would improve airflow over the condenser when parked.
Old Apr 13, 2007 | 01:28 PM
RobertH's Avatar
RobertH
I have the same problem. Last summer, I was very tired of it. Was thinking of putting on a additional pusher fan in the front. Others have done this, but I was not sure how to hook it up to the AC on wiring with the relay.
Anyone else done this mod?
Old Apr 13, 2007 | 02:01 PM
Monsta's Avatar
Monsta
Sit. Stay.
I don't think you need to hook it up the AC, per se. Just make it a manual switch. When you're idling or in stop-n-go traffic, flip the switch to activate the fan.
Old Apr 16, 2007 | 11:42 AM
RobertH's Avatar
RobertH
I hear ya on that ,but I would forget it is on and think that it would be better if it was turned on only when the a/c was activated. Then it is automatic like the rest of the system.
My bets are that there is someone around that knows which wire color is the ON wire and could tap into it into a relay then to the fan. Could also use the switch for a manual override in case of the unlikely stuck thermostat to help cool down temporarily.
Old Apr 16, 2007 | 11:50 AM
ZBeeble's Avatar
ZBeeble
Some of us have vastly improved this situation by disabling the EGR circuit (I'm sure there's a thread somewhere on that). The EGR circuit cools down your exhaust gasses with engine coolant and places a big load on the cooling system. The EGR is most active at idle.
Old Apr 16, 2007 | 04:22 PM
Brians97F250Crew's Avatar
Brians97F250Crew
your problem is just lack of air flow through the condenser. Put a fan on it and it'll be good. I did it last year I'm in FL and it made a world of difference.
Old Apr 16, 2007 | 05:08 PM
weekendwander's Avatar
weekendwander
It isn't only a lack of airflow but also a lack of engine speed. The compressor isn't at full output at an idle either.
Almost all AC systems are like this. A little more engine speed and things work perfect.
One other possible cause is you are slightly low on gas in the AC system. A few OZ may help.
Old Apr 17, 2007 | 08:12 AM
RobertH's Avatar
RobertH
I am good on freon. Just need to add some extra air at idle. Brains, how did you add your fan? I would like to put one on, but would like it to be controlled by the AC On and not manual so I have to turn it off and on every time I stop.
Old Apr 17, 2007 | 08:19 AM
Brians97F250Crew
I added a pusher in front of the condenser. Think it was a 16" and I wired it into the clutch switch.
Old Jul 9, 2007 | 01:36 PM
RobertH's Avatar
RobertH
Brians, I don't think I ever did catch backup on this conversation. Must be getting old or something......
How is the fan doing? Are you happy with it? Can you elaborate on how you hooked it up?
Old Jul 9, 2007 | 03:39 PM
jackrista's Avatar
jackrista
why not just wire it when the key is on the fan is on when key is off fan is off that would be easist
DeputyDawgAtl
Escape & Escape Hybrid
Jul 2, 2015 10:21 PM
DaytonaTunnel
1983 - 2012 Ranger & B-Series
Apr 2, 2014 02:11 PM
mshargrave23
Sep 15, 2013 12:02 PM
bodabdan
Mar 13, 2012 08:44 PM
