Offroad & 4x4
what rim for a 38 tall tire?
Old Mar 18, 2006 | 05:11 PM
theguy_88's Avatar
theguy_88
Question what rim for a 38 tall tire?
i have a 77 f-250 crewcab 4x4 that im going to put 38 inch tires on 16.5 rims what rims do i need what offset and how wide do they have to be or will the stock wheels work? the tires i belive are 38x15x16.5 super swamper trl radial. and what are the stock size of a 16.5 rim (the off set and back spacing and width)?
Old Mar 18, 2006 | 05:27 PM
BroncoRoadKill's Avatar
BroncoRoadKill
I would go with 16s cause There have been lots of problems with 16.5s smaller beads and the tire can get poped off the bead alot easier than any other size. Just what I have heard.
for a 15 wide tire,I would go with atleast a 12 wide rim, or even 14.
Old Mar 18, 2006 | 05:48 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Yeah...the 16.5 wheels are not good at all for holding beads. I would stick with a 16x12 wheel.
Old Mar 18, 2006 | 07:20 PM
chrono4's Avatar
chrono4
is this truck going to be a pavement pounder, or a mainly offroad truck? if its for the road, get a wider rim, as it will make the tires wear better, if you plan on mainly being offroad, get a skinnier rim, it will help hold the tire on the rim, but if you run a skinny rim on the road alot it will wear the middle of the tire more.
Old Mar 18, 2006 | 07:23 PM
fordraceboy's Avatar
fordraceboy
16.5s smaller beads
it's not so much the fact of a smaller bead, it's that the bead on a 16.5 is angled a about 45 degrees- where a 16" is straight up and down bead so the surface area is greater... if you run a 16" wheel and a 15" wide tire you can go as narrow as 8" or so.. the tire jockeys don't like you but you can air them dowm and they won't break a bead without some serious effort... i run 38.5x15 boggers on 16x8 wheels and haven't lost a bead yet- and hae been down to as low as 8 pounds in the tires...
Old Mar 18, 2006 | 07:51 PM
theguy_88's Avatar
theguy_88
well i got the tires cheap and my truck has 16.5 stock wheels and i was thinking that could i use my stock rims and if i get some extra cash i was going to buy new rims but thats a ways down the road. and searching the net i found out that for the tsl radial 38x15x16.5 the Tread Width is 11.50 in and the Recommended Rim Width 9.75 in. but will the stock rim width work
Old Mar 18, 2006 | 07:57 PM
chrono4's Avatar
chrono4
thelll work, just about any width will, its just how well
Old Mar 18, 2006 | 08:42 PM
fordtruggy's Avatar
fordtruggy
Do you have any pictures of these tires?I have been lookin at doing this but wasnt sure how it would look.A pic would be appreciated,thanks.
Old Mar 18, 2006 | 10:01 PM
74 F100 351m's Avatar
74 F100 351m
I have 38x13x16's on 16x6.5's They are on the 73, have photos.
Old Mar 19, 2006 | 11:40 AM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
they will work.....may rub on the leaf springs....and you will have to air them down a good bit to get proper wear if you driveit on the road. other than that they will work great for holding a "bead"
Old Mar 19, 2006 | 03:54 PM
fordraceboy
just got some pics... i'll be posting them in my gallery later tonight...
Gear619
Mar 10, 2015 01:44 PM
theguy_88
Offroad & 4x4
Mar 19, 2006 03:42 PM
theguy_88
Mar 19, 2006 09:47 AM
theguy_88
Mar 18, 2006 09:18 AM
Doorgunner808
1978 - 1996 Big Bronco
Oct 13, 2004 11:49 PM
