55 oil question
Old May 19, 2026 | 07:19 AM
my1955F100's Avatar
my1955F100
55 oil question
When I found my 55 a few years back, it had the 223. It was getting tired so I located a 58 292 which i rebuilt and swapped. I'm looking to change the oil and know it takes a high zinc 10W30 or 40. Does anyone know which brand to get as a best option and where to get it? Any help is much appreciated.
Old May 19, 2026 | 07:54 AM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
Any oil is better than no oil. There isn't a common automotive engine oil that will absolutely trash your engine. Getting into the specifics of which specific oil to run will get a different answer from anyone you ask depending upon their biases and preferences.
I run straight SAE 30 Motor Oil with a Zinc ZDDP Additive is about as close as one can get to what Ford calls for and change it at the beginning of every driving season.
Some people use 10W-40 Diesel Oil (or similar) thinking that its additives are beneficial to the flatheads/older engines, but the zinc additive formulation is usually different than what is used for gasoline engines and not nearly as useful. There is uncertainty out on how these other additive packages/formulations are compatible over time. I think this diesel oil preference gets perpetuated around due to the novelty of the "life hack" or that "I know something you don't" mentality.
If not using the original spec straight SAE 30 Motor Oil coupled with a ZDDP Additive, any modern multi-weight XW-30 Motor (not diesel) with a Zinc ZDDP additive will likely suffice.
The traditional wisdom is that synthetic oil will have tendency to liberate old sludgy deposits in the oil system. Some of these deposits may have been acting as a seal and so it has the potential to highlight weaknesses by weeping and leaking. Also, some of the liberated deposits may relocate to a inconvenient place and crate a new more problematic restriction.
Again, for what it is worth, I run straight SAE 30 oil in my engines coupled with Rislone ZDDP treatment. Straight 30 conventional oil is not as prevalent on the shelves as it once was.
Old May 19, 2026 | 08:07 AM
55F250's Avatar
55F250
AirForceVet
Question
When you found your truck, very nice looking truck by the way, and it had the 223, did it have the V8 emblem on the grille?
Old May 19, 2026 | 10:06 AM
abe's Avatar
abe
The OP swapped in a rebuilt engine so I don't think there are chunks of sludge that will dislodge and cause problems. I use 10w30. Some say old engines should use 10w40. The thinking is 40 weight would leak less???? What do some of you think?
Old May 19, 2026 | 10:47 AM
F100supercrew's Avatar
F100supercrew
I use this for years --LUCAS HOT ROD--CLASSIC motor oil-- SAE 20W-50w HIGH IN ZINC-- ( LUC- 10689-1 )---GET IT AT summit-- OR EBAY
Old May 19, 2026 | 01:56 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
As far as oil brand and weight, choices are as scattered as colors of trucks. It all depends on how YOU use your truck and what is available near you. And as mentioned the zinc additive is something you can add to what ever you chose to run. If you put in the additive it opens the door to almost literally hundreds of choices between brands, weight, additive packages, etc... Either provide a lot more info or better yet make a choice your good with and run it.
Old May 19, 2026 | 02:19 PM
my1955F100's Avatar
my1955F100
I really appreciate the info and especially the detail behind it. I'm going to go with SAE30 and a zinc additive. Thanks much for your reply.
QUOTE=bmoran4;21830131]Any oil is better than no oil. There isn't a common automotive engine oil that will absolutely trash your engine. Getting into the specifics of which specific oil to run will get a different answer from anyone you ask depending upon their biases and preferences.
Again, for what it is worth, I run straight SAE 30 oil in my engines coupled with Rislone ZDDP treatment. Straight 30 conventional oil is not as prevalent on the shelves as it once was.[/QUOTE]
Old May 19, 2026 | 02:33 PM
my1955F100's Avatar
my1955F100
Forgot to answer the question about the V8 grill emblem from 55F250. Short answer is that it originally had a chrome, 4 point star. When I swapped out the 223 for the 292 I rebuilt, I replaced the star with the V8 emblem. I know it's not OE correct from a purists perspective, but it makes me smile and feel good about the work it took to make the conversion. Otherwise, everything else is original to the truck. The color Regatta Blue, was original but it may have been an option. I never saw it on the 55 truck paint color sheet but I know it was available on the 55 Thunderbird. Restoration took about 8 years but I'm pretty close to being all done, if you ever are on a 71 year old truck! Lol
Old May 19, 2026 | 03:59 PM
mOROTBREATH's Avatar
mOROTBREATH
FWIW you don't really need high zinc/ZDDP oils for low performance, stock valve spring engines. The real issue is for high lift cams and high pressure valve springs.
I haven't run high zinc or added additional zinc to my oil in my 223 or other old cars I own in several years. I run synthetic 5w-30 year round here in CA in my 223, in my caddy 500 in my other car as well.
Old May 19, 2026 | 04:16 PM
8pack's Avatar
8pack
I am using Shell Rotella T4 10w-30. It's has 1200 ppm of ZDDP which is one of the highest levels available in an oil. When I researched it that seemed to be the recommendation for a flat tappet cam. It may not be necessary but I am a belt and suspenders kind of guy.
Old May 20, 2026 | 07:48 AM
Steve's Avatar
Steve
I use Shell Rotella 15w-40 in our mild SF Bay Area climate. I check the valve lash in the 292 every couple of years or 6,000 miles and they are always at 0.019". I extrapolate that to suggest the oil is doing it's job.
Old May 20, 2026 | 11:26 PM
Oldb's Avatar
Oldb
I have found the forum "Bob is the oil guy" to be a great resource for oil related questions.
B
Old May 21, 2026 | 08:41 AM
bigwin56f100's Avatar
bigwin56f100
I'm with you on this. I've never been concerned s as bout zinc or lead. I've owned and driven some of these vehicles for almost 30 years. I make sure of 2 things. Oil is clean. And oil is full.
I do prefer to use conventional oil just because it's what they have been using but I'll use any conventional oil 5/30 10/30 10/40 15/40 20/50 or 30wt
there are deals for oil on market place and garage sales. I just bought a new 5 gallon bucket of gear oil for $50 these old cars and truck and tractors I'll use it.
Old May 21, 2026 | 09:44 PM
mOROTBREATH
$50 for 5 gal is crazy good deal, especially if you have tractors like you do.
Old May 22, 2026 | 05:36 AM
bigwin56f100
I know. I bought 2 quarts of synthetic gear oil for my 2015 jeep when I changed the rear end. With my friends account it was $48. That's just nuts
arthall
Sep 15, 2025 06:43 PM
Matt1966
Oct 13, 2023 10:22 AM
sand_fiend
Oil & Lubrication
15
Jul 11, 2011 04:46 PM
jkh04200
May 3, 2007 11:15 PM
bad ass diesel
Nov 5, 2004 06:05 AM
