oil additive?
Old Nov 4, 2004 | 05:29 PM
bad ass diesel's Avatar
bad ass diesel
oil additive?
i saw power service oil additive at wal-mart the other day, any 1 hear anything about it? says its supposed to add life to your oil
Old Nov 4, 2004 | 06:55 PM
Quadzilla's Avatar
Quadzilla
I wouldn't add anything to the oil on a Powerstroke. The product you mentioned might very well work well in gassers, but your oil has too many important tasks in a diesel to alter it at all.
Old Nov 4, 2004 | 07:00 PM
MTMike's Avatar
MTMike
I've seen a product that reportedly extends the oil life on diesel engines. I think that is what he is refering to. As I recall, it replaces the additives that are worn out/gone. It is about $18 a gallon so I saw no sense in using it.
mike in montana
Old Nov 4, 2004 | 08:22 PM
Domino'sDiesel's Avatar
Domino'sDiesel
Our injectors run on oil pressure and the oil designed for our rigs has an anti-foaming agent. An additive will change the characteristic of the oil and cause the truck to run rough and probably do harm. I would not use an additive under any circumstances even if the manufacturer says it's o.k. How long would you want to run your oil without a change? A diesel's motor oil will last a couple thousand miles longer than a gasser. Diesel oil change 3,000- 7,000 pretty much depends on how hard you drive it.
Old Nov 4, 2004 | 11:16 PM
johnsdiesel's Avatar
johnsdiesel
I agree with the opinions offered above, but want to add an example. The Lucas demonstration at my local auto parts store actually demonstrates that you should not use it. I was able to get the oil to foam simply by cranking their little set of gears. Foam=Real Bad in a diesel engine.
Old Nov 4, 2004 | 11:23 PM
Kwikkordead's Avatar
Kwikkordead
Yes, stay away from additives. Extreme injector indigestion due to excess gas in the oil.
Old Nov 5, 2004 | 06:05 AM
blackf3504dr's Avatar
blackf3504dr
Hey Kwikk'...... Would Tums help ?! LOL !
