Toe in adjustment
Old May 17, 2026 | 11:44 AM
55F250's Avatar
55F250
AirForceVet
Toe in adjustment
Okay, I know there other adjustments, camber and caster, right now I want to get the toe in as close to what it should be which I believe is 1/16 in. I got it as close as I could using 1/2" EMT clamped across the front of the brake drum hub assembly (should have taken a picture). Then I measured from the outside of the frame to the center of the conduit to where I was as close to 1/16" toe in on both sides. What are some of the ways others have done this?
Old May 17, 2026 | 12:19 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Toe-in is measured at the rim of the wheel. You need to measure at the front and back of the wheel to get the difference. If you can find a wooden dowel that fits inside your EMT, and mark where the dowel sits at F&R, it will be pretty darn close.
Old May 17, 2026 | 12:52 PM
55F250's Avatar
55F250
AirForceVet
I should have explained better, the EMT conduit is long enough to where I can measure both front and rear from the frame to the center of the conduit. I just went for a drive, it steers fine but likes to wander especially in a curve. I have some 15" wagon wheels, I had to use 1/8" spacers because the drum would hit the inside of the wheel before it was seated against the drum/hub. With the wheel and tire off I use the spacer to clamp the conduit to the drum/hub. Looks like I still need some fine tuning.
Old May 17, 2026 | 01:04 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
You need to measure tire to tire, not drum or hub. The frame should not be in your equation at all. And if I read you post you had 1/16 toe-in each side, that is 1/8" total, which may be fine depending on suspension, tire size and type (radial v.bias).
Old May 17, 2026 | 01:05 PM
truckeemtnfords
It also sounds like your method has no weight on the suspension, which also is not good.
Old May 17, 2026 | 02:02 PM
52 Merc's Avatar
52 Merc
Probably the most common way guys at home set toe is with a tape measure, measuring the front tires center to center in front of and behind the tire, comparing and adjusting the tie rod as necessary. I agree measuring to/from the frame to wheel will not be accurate.
Old May 17, 2026 | 02:32 PM
55F250's Avatar
55F250
AirForceVet
Thanks guys, never thought about weight of the truck and the other considerations, so I'll give it another try and see what happens with the tires mounted.
Old May 17, 2026 | 05:14 PM
ingo's Avatar
ingo
Adjusting the toe-in has already been explained in detail here, so that’s the first thing you should do.
If the vehicle tends to wander off course or the steering feels twitchy, this could be due to your wheel spacers, for example.
These alter the steering roll radius, so you should also make sure to install wheels with the appropriate backspace.
Old May 18, 2026 | 05:03 AM
Marten's Avatar
Marten
When I had a race car I used something like this. Actually just a couple of pieces of steel or wood and 2 tape measures. Put the edges of the tape next to the tire. You want them at the same height off the ground on both sides of the truck.
https://www.speedwaymotors.com/Longa...gnets,502.html
Old May 18, 2026 | 06:02 AM
55F250's Avatar
55F250
AirForceVet
Actually it was tracking better before I messed with it the other day. I thought I could make it better, I should have left it alone. The wheel and tire combination I'm using works fine even with the 1/8' spacer. Thanks
Old May 19, 2026 | 07:00 AM
Vegastype's Avatar
Vegastype
Get yourself one of these:
Toe Stick Toe Stick
Here is a video of someone using it to adjust toe on a Model A
Old May 19, 2026 | 07:22 AM
55F250's Avatar
55F250
AirForceVet
Toe Stick
https://youtu.be/LdNb-NU9vf0?si=iulwzsjsPflFSbNH
That's the ticket right there! Thanks for sharing!
Old May 23, 2026 | 08:13 AM
55F250's Avatar
55F250
AirForceVet
Wink
Got the steering alignment adjusted, steers great.. measured from frame to center of both tires while resting on the ground. This got both wheels/tires parallel to the frame, this was with the tie rod removed. I then dropped a bolt into the hole where the tie rod end would be. I measured the distance from bolt to bolt, checked this against the tie rod and made adjustments. I installed tie rod and checked measurements both front and rear, adjusted to 1/16th to 1/8" toe in. Maybe not the way some people would do it but, as a old boss once told me, "we ain't building no piano!"
Old May 24, 2026 | 04:57 PM
hooler1's Avatar
hooler1
That's a great way to do it!
Twice I used a long piece of 1/8" thick straight steel stock.With the front wheels off I would just slide around the back of the backing plate and it would hold itself there between the backing plate and the king pin outer boss. Then I meaured between the 1/8" steel ends to the frame and squared up both backing plates to the frame while adjusting the tie rod. Then added a 1/16 in toe to each side. Both times two different alignment shops told me it was good and I could leave it there if I wanted or they dial it in just a little closer. I had them do that. But it goes to show how close a home alignment could be.
cruisetopdown
Jan 18, 2013 12:46 AM
66f250352
Oct 3, 2012 12:50 PM
DumbLuck
Oct 11, 2011 04:31 PM
cashs66
Jun 27, 2003 10:04 AM
Danlaws
Oct 22, 2001 08:46 PM
