Throttle Position Sensor woes.
Old Feb 21, 2026 | 06:13 PM
BrownOBS's Avatar
BrownOBS
1997 F-350, 7.3L E4OD. I pinned down some rough running and an unstable ideal to a bad throttle position sensor. Probing the original sensor showed erratic voltages from closed to wide open throttle, so I ordered a new TPS and installed it. Fixed everything: smoother idle, better throttle response, everything was great... until a week or so later I got a crank no start and found infinite resistance on the brand new TPS. I figured it was just another case of crap QA and took it back to the parts store for another. Thankfully the truck was in a safe place to leave it. Put another sensor in and everything was good... for another week and then again: crank no start.
At this point, subpar quality of replacement parts withstanding, I have to assume there is something else that is killing the TPS.
I'm hoping some of the vast knowledge on this forum can help me out. I'm sure the parts store will keep exchanging the dead TPS for another one... that will have to be ordered... but I'm gonna have a failure at some point somewhere that isn't safe.
Thanks for reading, I am all ears to a potential solution.
Jeremy
Old Feb 21, 2026 | 08:13 PM
defdes's Avatar
defdes
Jeremy
Sorry for the woes, no insight here other than I always order Motorcraft parts where possible, not saying that this is the issue but if you get it sorted, better to order OEM on these critical elements.
Old Feb 21, 2026 | 08:39 PM
BrownOBS's Avatar
BrownOBS
I generally agree. Motorcraft sensors definitely perform better... when and where they're available.
Dorman is the only reputable manufacturer currently making the sensor.
I appreciate your input, but I don't believe it's a quality of part issue. I believe it is deeper than that.
Jeremy
Old Feb 22, 2026 | 11:39 AM
Hit Man X's Avatar
Hit Man X
How is your idle validation switch?
Red96351
Aug 16, 2023 11:35 AM
80driver
1983 - 2012 Ranger & B-Series
Oct 9, 2017 03:04 PM
gijoe985
1997 - 2003 F150
Jul 15, 2008 11:03 AM
Craig64
Jun 6, 2008 06:42 PM
Iron Horseman
Mar 23, 2006 04:28 PM
