TPS being weird
Old Aug 15, 2023 | 10:39 PM
Red96351's Avatar
Red96351
4wd Low
TPS being weird
So. On the last tps sensor I replaced I had a little green oring/gasket type deal that went onto the probe that connects to the tb and it worked fine. This new one I changed out didn’t have that but I replaced it anyway and now it’s not even showing a reading on my scanner for throttle percentage. I was hoping someone on here could grant me with some wisdom as I’ve not messed with the sensors to much
Old Aug 16, 2023 | 05:24 AM
My4Fordtrucks's Avatar
My4Fordtrucks
The last sensor you replaced? How long ago was that and why are you replacing it again? I hope you are using Motorcraft sensors. Did you install the sensor correctly so that the tabs on the throttle body are turning the sensor when the throttle is opened?
I don’t remember there being an o-ring but I haven’t replaced a TPS in a long time. Did you try reusing the one from the old sensor?
Another question for you… what vehicle are you working on?
Old Aug 16, 2023 | 09:58 AM
Red96351's Avatar
Red96351
4wd Low
I replaced it the first time about 8 months ago. It’s a 1996 f150 with the 351. I used a standard ignition sensor since they were cheaper and have a lifetime warranty at the store I worked at. The spacer was like lime green and about 1/4” height.
Old Aug 16, 2023 | 10:11 AM
My4Fordtrucks
Cheaper isn’t better for sensors.
Old Aug 16, 2023 | 10:12 AM
Red96351's Avatar
Red96351
4wd Low
I get that but I didn’t have the money at the time
Old Aug 16, 2023 | 11:31 AM
My4Fordtrucks
You got a code for and have tested the sensor?
Old Aug 16, 2023 | 11:35 AM
Red96351's Avatar
Red96351
4wd Low
Code p0122 and haven’t had time to test it
tpayne
Jan 28, 2022 06:07 PM
Superduty.pride
Oct 13, 2011 12:08 PM
cdknechtel
1997 - 2003 F150
Apr 18, 2009 02:13 PM
BadHabitinVA
1983 - 2012 Ranger & B-Series
Feb 22, 2008 02:53 PM
351slug
Aug 15, 2007 06:13 AM
