1997 F-350, 7.3L E4OD. I pinned down some rough running and an unstable ideal to a bad throttle position sensor. Probing the original sensor showed erratic voltages from closed to wide open throttle, so I ordered a new TPS and installed it. Fixed everything: smoother idle, better throttle response, everything was great... until a week or so later I got a crank no start and found infinite resistance on the brand new TPS. I figured it was just another case of crap QA and took it back to the parts store for another. Thankfully the truck was in a safe place to leave it. Put another sensor in and everything was good... for another week and then again: crank no start.
At this point, subpar quality of replacement parts withstanding, I have to assume there is something else that is killing the TPS.
I'm hoping some of the vast knowledge on this forum can help me out. I'm sure the parts store will keep exchanging the dead TPS for another one... that will have to be ordered... but I'm gonna have a failure at some point somewhere that isn't safe.
Thanks for reading, I am all ears to a potential solution.
Jeremy
Sorry for the woes, no insight here other than I always order Motorcraft parts where possible, not saying that this is the issue but if you get it sorted, better to order OEM on these critical elements.
