e4od transmission not moving
Old Nov 4, 2025 | 06:05 PM
kitz's Avatar
kitz
just got done installing a reman e4od auto trans in my 97 f250hd i went thru the procedure of filling with fluid run 15 seconds add 2 qts run 15 seconds add 2 qts then move shifter thru gears put in park check fluid and it is way overfilled ran thru gears again and wheels are not moving torque convertor evidently not locking up dont sound like any solenoids are operating how do i test to see if trucks solenoid wiring harness is working i am assuming that the trans and convertor are good anyone have a wiring and plug diagram?
Old Nov 5, 2025 | 08:21 AM
1Butcher's Avatar
1Butcher
I have a 95 F250 5.8/E4OD/2WD. It holds well over 15qts. I do have an aftermarket aluminum pan, but it is a 2WD pan.
If the transmission can't pump what little fluid you put in is, the pump is probably not working. That can happen if the converter was not installed properly.
Old Nov 5, 2025 | 09:53 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
How many quarts total did you put in it?
There is NOTHING electrical that can keep it from engaging in gear. Nothing the solenoids do or do not do can make this happen. I think you don't have enough fluid to make it work.
Old Nov 5, 2025 | 11:03 PM
kitz's Avatar
kitz
i had 13 qts in it and it didn't move on dipstick apparently the pump is not working. i loosened the convertor nuts and the convertor moves so i am pretty sure i got it on all the way. sounds like i have to take it back out to see what problem is
Old Nov 5, 2025 | 11:11 PM
kitz's Avatar
kitz
i was pretty sure i got it on right i loosened the converter bolts and the converter moves. i seen a post that said to check that. don't know if that means anything but i figure i have to remove the tranny and check it to be 100% i ran it awhile to add fluid hope i didn't hurt it
Old Nov 6, 2025 | 08:23 AM
1Butcher's Avatar
1Butcher
I would test the line pressure to confirm your thoughts. Is is possible the transmission filter fell out?
Old Nov 6, 2025 | 04:03 PM
kitz's Avatar
kitz
i double checked the filter i called them today and they are sending me another trans determined pump is bad
Old Nov 13, 2025 | 06:52 PM
zzyzxpat's Avatar
zzyzxpat
A deep pan E4OD or 4R100 will hold approx 16-17 qts if dry.
Firs
Feb 4, 2023 05:16 PM
lakequ
32
Feb 24, 2018 09:21 PM
Cowboydesperado
48
Jun 4, 2013 07:52 PM
zottyzot
Nov 15, 2012 12:40 PM
