Y block crankshaft nose diameter
Old May 6, 2024 | 11:43 AM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
Can anyone confirm the front nose of a Y-Block's crankshafts diameter? The part the damper attaches to.
Old May 7, 2024 | 04:26 PM
ManFordman2's Avatar
ManFordman2
I measured the ID of the harmonic balancer/pully that I took off of my 292. I get 1.248 using a mic and a telescope gage.The shaft should be no more than .0005 smaller than the balancer, I think. I don't know what I did with the cam but if you want a more accurate OD, I can hunt it down.
Les.
Old May 8, 2024 | 07:39 AM
bjmayberry2
Thanks,
Hopefully your measurements will get my machinist what he needs.
Old May 8, 2024 | 01:40 PM
ManFordman2
Originally Posted by bjmayberry2
Thanks,
A machinists needs the exact number. I will mic the shaft today to be sure.
Old May 8, 2024 | 01:48 PM
bjmayberry2
That would be much appreciated.
Old May 9, 2024 | 01:10 PM
ManFordman2
I have a 239 CI motor with the front of the crank easily accessible. The nose of that crank measures 1.250. They should have the same nose diameter. I re-measured the damper and am getting 1.249 (I'm a little out of practice). The damper is from a 64 292 I can't imagine a reason for changing the nose diameter. Seems like a lot more press fit than would be required but I'm sticking to those two numbers. Your machinist will have good advice on that. It's a lot easier to take more off than to put some back on. Hope this helps.
Old May 9, 2024 | 01:26 PM
bjmayberry2
I really appreciate you measuring your crank. I'm reasonably sure all the Y block crank pulled will interchange. Mine is a 64 292 but I'm not sure what I got the damper from. It's the one with narrow grooves not 1/2" ones.
Old May 9, 2024 | 02:51 PM
ManFordman2
The one that I measured earlier is the same as yours. It measure about 13/32" at the widest part of the groove. The new one is the same.
Old May 10, 2024 | 03:47 PM
hiball3985's Avatar
hiball3985
Maybe I'm missing something, but why would you have to machine that part of the crank??????
Old May 10, 2024 | 10:20 PM
bjmayberry2
I’m making a degree wheel adapter. Not machining the crank.
Old May 13, 2024 | 09:31 AM
pintoplumber's Avatar
pintoplumber
BJ, you probably already know this, but Ted has a 3 part article on his website on how to degree in a camshaft. After I told him the trouble I had, he wrote the article.
Old May 13, 2024 | 12:48 PM
bjmayberry2
Yes Dennis, I got ahold of him after reading the articles over some confusion I had. He's gave me several pointers and suggestions. Glad there are folks like him, very few, that know these ole Y Blocks.
If you don't mind me asking how did you attach your degree wheel to your crank? With the key way set back so far you can't use one of the regular degree wheel mounting hubs. Like this.
Old May 13, 2024 | 01:59 PM
pintoplumber
I printed a degree wheel off the internet and glued it to cardboard. I used the bolt and washer from the crank and tightened it up. The 239’s don’t have a dampener. Fastened a wire to a bolt.
Old May 13, 2024 | 09:33 PM
bjmayberry2
Necessity is the mother of invention! Where there is a will there is a way. You are the man Dennis. I'm in $200 bucks on degreeing stuff.
77fordguy
General Automotive Discussion
17
Aug 3, 2005 11:04 PM
Adriand
Dec 14, 2004 09:42 PM
t_dickie
Dec 14, 2004 02:27 PM
Trader Bob
35
Apr 10, 2003 05:27 PM
Skyking
Aug 4, 2002 11:38 PM
